What is meant by no gas enters or leaves the cylinder ?
  • Thread starter Thread starter hahaha158
    Cylinder Gas
The discussion revolves around the implications of the phrase "no gas enters or leaves the cylinder" in the context of a piston supporting a platform with compressed air. Participants explore the relationships between pressure, volume, and temperature in a closed system, particularly focusing on how these variables interact when a load is removed from the platform.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the implications of constant pressure and volume in relation to the gas laws. They question how changes in temperature and volume affect the system when the pressure supply is closed. There is also inquiry into the relationship between the area of the piston and the volume of gas, as well as the effects of removing weight from the platform.
The conversation is active, with participants providing insights and questioning each other's assumptions. Some guidance has been offered regarding the relationships between pressure, volume, and temperature, but there is no explicit consensus on the implications of the closed system. Multiple interpretations of the problem are being explored.
Participants note that the pressure mentioned is gauge pressure, which may affect calculations if atmospheric pressure is not considered. There is also a focus on the conditions under which the system operates, such as the assumption of constant temperature and the effects of changing load on the platform.
hahaha158
What is meant by "no gas enters or leaves the cylinder"?
I have the following question.
A platform is supported on a piston by compressed air in a cylinder.
The mass of the platform and equipment being lifted is 1100kg. The pressure needed to
support this mass is 800kPa, and it rests initially at a height of 0.5m. The pressure supply
is closed so that no gas enters or leaves the cylinder
. One of the pieces of equipment with a mass of 50kg is moved o the platform. The entire system is at room temperature (300K)
I am confused with the significance of the bolded line. I'm not sure whether it's implying constant volume, constant pressure, temperature, etc. Can someone explain this?
P*V=n*R*T
from question; P don't change, and there is a finite amount of gas in chamber (i.e. n don't change)
so P don't change, n don't change (and R is a const. so it don't change), then what else could change (hint. if T change, then V change)
Ned Stark said:
P*V=n*R*T
Would the area change in this case? Because I need the area to find the volume, and according to my calculations it seems like it should, but it also seems a bit weird for the area of a platform to change
No, the area of the piston does not change. But the piston can move up or down. Some weight is removed from the platform: that means the external force decreases. To get into equilibrium at the same temperature (300 K) what parameter of the gas has to change?
Initially the internal and external forces acting on the piston are in equilibrium: The weight of the 1100 kg load is balanced by he force the gas exerts when its pressure is 800 kPa. So what is the area of the piston?
ehild
ehild said:
No the area of the piston does not change. But the piston can move up or down.
ehild
sorry the question is
what is the new position of the platform?
so i was referring to the area of the platform, not the piston.
The platform is supported on the piston. What does it mean?
ehild
ehild
If the area is unchanging can we simplify the equation PV=nRT become
h=T since everything else is a constant or unchanging?
How would this relate to the mass though?
edit:i meant h=t when comparting the two heights so for this case
0.5m/300K = height2/T2?
The temperature does not change. The pressure does.
ehild
ehild
Oh so according to the equation PV = nRT the only variables that change are P and V (since h changes)?
I'm a bit confused because I thought the above poster told me that pressure remains constant.
Yes.
He was mistaken.
Think. What does it mean that some of the load is removed?
ehild
ehild said:
Yes.He was mistaken.
ehild
If the load is removed then the height will increase.
So iare there any errors in the following solution?
find area using Pi=mig/A
A*h=Vi
find Pf using Pf = mfg/A
PiVi = PfA*h to solve for the unknown height?
thanks.
It is correct if the whole thing is in vacuum. Otherwise the 800 kPa is the gauge pressure, and the absolute pressure of the gas is 800 kPa +atmospheric pressure. As it was not mentioned, I think your solution is correct. ehild
ehild
ok thanks a lot for the help
You are welcome.
ehild
ehild said:
You are welcome.
ehild
sorry.
just one last question
the question asks for the maximum velocity
according to W=PdV
W should remain constant
and then using W=.5mv^2
wouldn't that mean you use mf since m is inversely proportional to v and m is smalest at mf?
Write the original question, please.
ehild
ehild
is closed so that no gas enters or leaves the cylinder. One of the pieces of equipment with a mass of 50kg is moved o the platform. The entire system is at room temperature (300K)
A)what is the height of the platform after the weight is removed?
B)what is the maximum velocity?
The gas exerts force and does work on the platform. That work increases both the potential and kinetic energy. The kinetic energy is maximum at the equilibrium height you calculated before, when the resultant force on the platform is zero, that is, the acceleration is zero. The platform will rise above the equilibrium height till the velocity becomes zero; after that, it moves backwards (ignoring friction).
ehild
11K
