Understanding Reverse HFE in Transistors for Audio Circuit Protection
  • Thread starter Thread starter bitrex
    Reverse
Reverse Hfe refers to the behavior of a transistor, such as the 2SC2878, when the collector and emitter are swapped, allowing it to operate effectively as a switch rather than an amplifier. In this mode, the transistor can turn on with a negatively biased base-emitter junction, making it suitable for applications like power-on muting circuits to protect speakers from turn-on thumps. The reverse Hfe value is typically low, around 0.02, indicating that while it performs poorly as an amplifier, it excels as a switch with minimal collector-emitter voltage drop when saturated. This design choice is beneficial in circuits where AC signals are present, allowing for efficient signal shunting. Understanding reverse Hfe is crucial for optimizing transistor performance in audio circuit protection.
bitrex
What is "reverse Hfe"?
Hey everyone, I'm looking over a synthesizer schematic that has a 2SC2878 transistor in shunt with the main output - I think it's connected up in some kind of power on muting circuit for protecting speakers against turn-on thumps. Interestingly, this transistor has something called "Reverse Hfe" - I assume this means for an NPN transistor it will turn on if the base-emitter junction is negatively biased as well as positively? I've looked on the web and can't seem to find a good explanation of how such a transistor would be manufactured.
The datasheet for the device is here: http://www.datasheetarchive.com/pdf-datasheets/Datasheets-38/DSA-757294.pdf
The circuit in question is: http://img9.imageshack.us/img9/9071/alphajuno.th.jpg
Any insight into how this circuit works would be appreciated - I guess it somehow keeps the 2SC2878 turned on until the positive and negative rails stabilize?
It's referring to the hfe value when emitter & collector are swapped. This is referred to as inverse or reverse mode of operation.
The reverse hfe value is typically less than 0.1, more like 0.02 or so. In this mode, the bjt makes a lousy amplifier, but an outstanding switch. In the reverse mode, when driven into saturation, the collector-emitter voltage drop, Vcesat, can be tens of millivolts. That is hard to achieve in the normal, or forward mode.
Claude
All transistors have a reverse Hfe as you can always reverse the position of the collector and emitter. It's equivalent (but not strictly identical - Hfe is large signal, BF is small signal hybrid-pi) to the SPICE parameter BR just as BF is equivalent Hfe.
If you operating the amplifier as an amplifier, the lower the reverse gain the better because it represents a "parasitic" reverse BJT operating in the opposite direction. Amplifiers are closer to ideal when they are unilateral in gain. As @cabraham says, having forward and reverse transistor characteristics bilateral (equal) makes for a bad amplifier but a good (bilateral) switch. An asymmetric device can be a good switch if the switched current will be flowing in only one direction (collector to emitter) like an amplifier.
Because this transistor effectively has AC on its collector, they have chosen a transistor that works well with either polarity on it.
It has AC on it because it is being used to shunt capacitively coupled signals to ground.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
