Berbit said:
Hello FF,
Thank you, yes, I understand that aspect of the Higgs (at least superficially). I've read Sean Carrol state that without the Higgs the leptons would be the same particle, including, for example, the electron and the e-neutrino.
This is subtly wrong. "Electron and the e-neutrino would be the same particle" only in a sense that green quark and blue quark are often said to be "one type of particle", just quark. But in many cases, they have to be counted as separate types of particles.
If you remove Higgs field from SM, the electroweak force will not reduce to electromagnetism, it will be still "unbroken" and consist of:
Weak hypercharge force, with properties very similar to electromagnetism - massless uncharged B bosons quanta are carriers, each left-handed lepton has -1 weak hypercharge, each right-handed electron-type lepton has -2 weak hypercharge. (Right-handed neutrinos, if they exist, have 0 charge).
Weak isospin force, an always attractive force with three carriers W1, W2 and W3 who are themselves charged under weak isospin. It's somewhat similar to gluons and quarks, but having 2 "colors" instead of 3: they are called "up" and "down". Electrons and neutrinos are different here: left-handed electrons are "down"-particles, left-handed neutrinos are "up"-particles. W1 and W2 turn them into each other, W3 rotates the phase of their two components in opposite directions but doesn't mix components (which means it does not change "up"/"down"-ness). Right-handed particles are not charged under weak isospin. Unlike gluons and quarks, weak isospin force is not strong enough to exhibit containment: it does weaken with distance.
This picture is "spoiled" by the fact that not only Higgs, but QCD also has a quark-antiquark vacuum condensate (nonzero VEV), so there would be a much weaker form of higgs-like mechanism which would give (smaller) masses to particles.
