What is the Average Speed of a Car on a 100 Minute Trip?
To calculate the average speed of a car on a 100-minute trip, the car travels at varying speeds: v for 40 minutes, v/2 for another 40 minutes, and v/3 for 20 minutes. The total displacement is calculated as 40v + 20v + (20/3)v, while the total time is 100 minutes. The average speed is determined using the formula avg v = displacement / time, leading to an average speed of 33.33 km/h. There is confusion regarding how to eliminate the variable v, with some suggesting that the average speed can only be calculated if a specific value for v is provided. Ultimately, the average speed of 33.33 km/h is derived under the assumption that v is 60 km/h.
cmkc109
A car travels at a speed v (km/h) for 40 minutes, then at a speed v/2 for 40 minutes, and finally at a speed v/3 for 20 minutes. What is the average speed for the trip
40v + 20v + 20/3 v = displacement
time = 40+ 40+ 20 = 100minutes
The answer given is 33.33
but, how do you cancel out the v.. I'm confused :(
the average velocity is (5/9)*v
what are the units of the 33.33
i don't remember :/ but in general, how to solve this question?
you can't eliminate the v unless it gives you a value for it. the only thing i can think of is that 33.33 is the average time per journey of the car. if it is asking for the average speed then v must have been 60 km/h.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
