What is the balance point between 2 gravitational bodies called?
The discussion centers on identifying the point where gravitational forces from two bodies, such as a floor and ceiling, balance each other. The term "Lagrange point" is mentioned but clarified that it does not represent a complete cancellation of gravitational forces. Instead, it provides the centripetal force needed for objects to maintain a stable position relative to orbiting bodies. Participants agree that "equilibrium" is a more appropriate term for a scenario where gravitational forces are equal and the player would float without moving toward either surface. The conversation emphasizes the complexity of achieving true gravitational balance in practical scenarios.
fosterboy123
Hi there!
My physics is not exactly strong (I am a games developer/designer).
Basically I have a game idea where the player will jump between the floor and the ceiling. At any point the player will jump and be affected by the gravitational point of the ceiling and the floor at the same time based on their position on the Y axis.
I understand the mathematics, but I am curious to if there is a name for the point at which the two gravitational forces are in balance (assuming both gravitational forces are identical in strength). I.e. is there a name for the point where the player would just float, not moving toward the ceiling nor the floor?
Thanks
Maybe point of equilibrium?
But I think it would be difficult, at least in real life, to sit directly at the point of zero net gravitational force. A fraction of an inch too far in either direction will pull you away.
Unless the room is spherical, then everywhere would have net zero gravitational force.
Yeah, I think Equilibrium sounds right!
I actually wanted to know simply for the name and I had no idea what it was called.
Thank you very much!
"Lagrange point" or " Lagrangian point" is the term you're looking for...
Not really. Lagrange point 1 is not where the gravity forces of two bodies cancel completely, but rather where their net effect provides exactly the centripetal force needed to stay in line with the two bodies, while they orbit:
http://en.wikipedia.org/wiki/Lagrangian_point#L1
my mistake...i didn't realize that the OP was looking for a point or region in which gravitational forces cancel completely. I guess I need to read more carefully first, b/c after having read the OP again, a stationary floor and ceiling scenario doesn't exactly work like actual orbiting bodies...
...in this case, i don't know that there is any better a term for this kind of cancelling of gravitational forces than simple equilibrium as suggested before i initially posted.
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
