What is the best computational software for a first year BS Mechanical student?
For first-year BS Mechanical students, MATLAB is highly recommended as the best computational software due to its extensive use and capabilities in engineering applications. While Mathematica and Maple are mentioned, they serve different purposes and may not be as beneficial for beginners. Octave is a free alternative to MATLAB that offers similar functionality. MathCAD is user-friendly and has a good interface, but it struggles with solving systems of equations, making it less ideal for engineering tasks. Overall, MATLAB stands out as the preferred choice for foundational learning in mechanical engineering.
Ali Asadullah
I am student of BS Mechanical first year. I want to which is the best computational software for this level, i.e. Mathematica, Matlab or Maple any other?
Thank You
Mathematica and Maple are not really the same type of software as Matlab. You will absolutely want Matlab. I (along with pretty much everyone I know) use it extensively and I have ever since undergrad. Mathematica and Maple can be useful but you will have to get someone else's opinion, as I have very limited experience with them.
For a 1st year I would recommend MathCAD
MathCAD is great, but lacks some fundamental features that are very easy to use with Matlab. MathCAD is easy to use, and has a great interface, but is terrible at solving systems of equations.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
