What is the controversy- current and resistance
  • Thread starter Thread starter i_island0
    Current Resistance
The discussion centers on calculating current through a resistor connected to two parallel voltage sources. Participants clarify that while internal resistance is assumed to be zero for ideal conditions, real-world applications require considering non-ideal characteristics of power supplies. The consensus is that the current through the resistor can be approximated as the maximum voltage of the two sources divided by the resistance, i.e., I = max(V1, V2)/R. Additionally, there is an emphasis on practical experimentation to reinforce theoretical understanding of circuit behavior. Overall, the conversation highlights the importance of grasping basic electrical principles and encourages hands-on learning.
i_island0
Why do you want to know?
You can't divide by 0
Although true, totally irrelevant.
I am guessing (since the image won't load) that you've got two different supplies in parallel with a load resistor?
Essentially you cannot have r=0 exactly... you'd have to take a limiting case which is highly dependent on the details of the power supplies. Examples include known r, limited current, perhaps the supplies cannot sink current etc...
Once you have the non-ideal characteristics of the supplies specified it is reasonably easy to determine the result.
As I understand this, R is not 0; r(internal) is zero and you can do the ideal case without too much worry.
So, what do you know about currents at a junction?
i want to know the current in R.
r is the internal resistance of the batteries, which i have assumed to be zero.
It is just two cells (power supplies) in parallel to a resistor of value R
The talk about little r confuses things, so just say in the ideal case. Since this is intro physics and a very basic circuit.
Two cells in series (say 2x1.5V, 500mAh types) gives you what current and what voltage if acting as a battery ?
Two cells in parallel (say 2x1.5V, 500mAh types) gives you what current and what voltage if acting as a battery ?
If you cannot answer this basic question, then I suggest picking your the first topic that pops up in google for say 'cells in parallel' and have a read
http://www.batteryuniversity.com/partone-24.htm
ah.. thanks for your answer. .. i m in the process of learning basics only.
In the parallel combination there, both the voltages are same, i.e. 1.2V, so the potential difference is 1.2 V. But if suppose one battery is 1.2 V and other is 1.5 V, then what is the potential difference we should say finally.
The way i have understood is that (1.2 V and 1.5 V ); 1.2 V is a lower voltage, so we will take it will just give low run time, and the final voltage across will be 1.5 V only.
So, for the question that i asked...the current i = max (V1, V2)/R.
If there is something wrong in my understanding, can u please correct me if possible.
thx again
If you really want to learn, go and do it...
Get yourself some batteries (not mians power supplies), a couple of resistor and voltmeter and ammeter.
Have a play and see what you get.
That should answer your question...
i wish i had that facility with me to experiment. Can you just tell me if i m thinking in the right direction?
Sounds good to me :approve:
