What is the current through each ideal diode in this circuit?
  • Thread starter Thread starter kliker
    Current Diode
The discussion focuses on calculating the current through ideal diodes in a circuit with a 10kΩ resistor and various voltage sources. The calculations yield currents of 1.13 mA for the first diode, 0 mA for the second diode due to reverse bias, 1.43 mA for the third diode, and 0.13 mA for the fourth diode. Corrections were made regarding the voltage across the diode and resistor in the third calculation, confirming that the voltage should be 10V instead of 15V.
  • Understanding of ideal diode behavior
  • Basic circuit analysis techniques
  • Knowledge of Ohm's Law
  • Familiarity with voltage source configurations
  • Study the characteristics of ideal diodes versus real diodes
  • Learn about series and parallel circuit configurations
  • Explore advanced circuit analysis techniques such as mesh and nodal analysis
  • Investigate the impact of temperature on diode performance
Electrical engineering students, circuit designers, and anyone interested in semiconductor device behavior and circuit analysis.
kliker
find current through each diode, suppose that they are ideal (use the second approach)
[PLAIN]http://img30.imageshack.us/img30/102/86772682.jpg R is 10kohms
a) (12-0.7)/10k = 1.13 mA
b) 0 because diode will be open, actually i added up the two voltate sources and i have a voltage source of 16Volts where + is connected with diodes - and - is connected with diodes + so its reverse biased, hence current will be 0
c) i added up the voltage sources i have 10 volts and its not reversed biased diodes voltage source will be 0.7
hence
(15-0.7)/10k = 1.43 mA
d) added up voltage sources i had a source of 2 volts
hence
(2-0.7)/10000 = 0.13mA
am i correct?
Yeah a,b and d are correct, but in (c), the voltage across diode and resistor is 10 v and not 15 v as you have put in the equation.
you are right, thanks a lot :))
  • · Replies 26 ·
  • · Replies 20 ·
