What is the deceleration of the ball?
The discussion revolves around calculating the average deceleration of a metal ball dropped onto sand. The initial approach incorrectly uses the time of fall as the deceleration time, neglecting the ball's velocity upon impact. Participants emphasize the need to determine the ball's velocity at impact and the distance over which deceleration occurs to accurately calculate deceleration. The question is deemed flawed, as it lacks sufficient information to derive an average deceleration without making assumptions about constant deceleration. A more precise question would clarify that it seeks the deceleration during the ball's compression into the sand, assuming it is constant.
Hussain
The question didn't fit there.
*A boy drops a metal ball from rest on sand. It hits the sand bed in one second and makes an impression of maximum depth 8mm in the sand. What is the average deceleration of the ball as it hits the sand? Assume air resistance is negligible.
vi= 0m/s
t= 1 sec
S= 8 mm or 0.008 m
a=?
I used S=vit+1/2(at^2)
By using that formula I got the answer 0.016 m/s^2 is it correct? Please tell me how to do it
Welcome to Physics Forums.
You are using 1 second as the time, but that is the time the ball is falling - not the time that the ball is decelerated by the sand.
Hussain said:
vi= 0m/s
This isn't correct: The ball is dropped from rest, but by the time it hits the sand, it already has a certain speed, as it is accelerated by gravity. So, what is ##v_i## when the ball reaches the ground?
Which formula should I use now?
The deceleration starts when the ball touches the sand. You need to know 3 things to solve. What is the velocity when the ball first touches the sand? What is the distance over which the deceleration occurs? What is the final velocity of the ball? You should use a formula which utilizes those 3 knowns and allows you to find the unknown (acceleration).
That is surely what the question intends, but the question is flawed. Average acceleration is Δv/Δt, so it would have to be possible to find the deceleration time. But there is not enough information in the question to find that.
We could find it by pretending the deceleration is constant from the instant of touching the sand to that of coming to rest, but that is clearly not the case, and the question would not need to ask for average deceleration.
A better wording would be "what is the deceleration as it presses into the sand, pretending it is constant?"
Likes TomHart
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
