What is the effect of permanent magnet strength in generator
The strength of permanent magnets in a generator directly influences the voltage generated, as it determines the initial magnetic flux. Increasing magnet strength can lead to higher voltage output, which requires more power at the shaft to maintain efficiency. While stronger magnets may allow for slower rotation to achieve the same power output, they also necessitate greater torque, impacting the overall design and performance of the generator. The relationship between power output and input remains consistent, governed by the load power consumed. Ultimately, the choice of magnet strength affects both efficiency and operational requirements.
Baluncore
athul jyothis said:
What all changes can we see if we use different types of permanent magnets with varying magnetic strength... I would like to know , will the work needed to rotate armature increases if we increase the strength of permanent magnet?
Baluncore said:
IMO this discussion should be in a public thread, not a conversation.
athul jyothis said:
how to do that pls help
Have you looked up how a dynamo operates?
Permanent magnet is the field so it sets initial flux
and voltage generated is flux X a constant for that particular machine X RPM
so. If increased voltage causes the machine to deliver more power to its load, well of course it'll require more power at the shaft.
In different words,
The work required is determined by the load power consumed. Power out = power in * efficiency
Stronger magnets mean you may not have to turn as fast to get the same power out. But, turning slower, you need more torque (have to push harder to produce the same power in), which may be desired, or not desired (depends on the drive system).
Depending on the design, different magnet strengths will affect the efficiency, but I'd consider that a secondary effect. (wow , effected a sentence using both effect and affect :) )
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
