What is the Electric Potential of a Uniformly Charged Ring?
The discussion revolves around calculating the electric potential of a uniformly charged ring and analyzing the motion of a charged particle displaced from the ring's center. The problem involves concepts from electrostatics and energy conservation.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • The original poster attempts to derive the electric potential using integration and expresses uncertainty about the correctness of their result. Some participants confirm the correctness of part a and suggest considering energy for part b. Others explore the relationship between potential energy and kinetic energy, raising questions about the variables involved, particularly the symbol 'd'.
Participants are actively engaging with the problem, offering guidance and clarifications. There is an ongoing exploration of how to handle the variable 'd', with some suggesting it should not appear in the final answer. The discussion reflects a mix of interpretations and attempts to clarify the setup of the problem.
There is a noted ambiguity regarding the definition of 'd' and its relevance to the problem, as well as the initial conditions of the particle's displacement. Participants are questioning whether 'd' should be related to other variables in the problem.
Cantspel
A ring of radius a is made from a charge wire with a uniform charge density λ.
a) Calculate the electric potential due to the ring as a function of distance from its center along the axis of the ring passing through the center, perpendicular to its plane
b) If a particle of mass m with a charge identical to that of the ring displaced ever so slightly from the ring's center what speed will the particle eventually attain after being repulsed by the ring.
V = k∫(1/r)dq[/B]
[/B]
So for a I drew the ring here is my best redraw of it in ms paint below. After drawing it i used dq = λ dL than i plug that into V = k∫(1/r)dq and I plug (a2 + d2)1/2 for r. getting me V = k∫(λdL)/(a2 + d2)1/2 getting me
V = (kλL)/(a2 + d2)1/2 since L = 2πa I can replace it in the fuction. So I get V = (2kλπa)/(a2 + d2)1/2
I have to clue weather or not this is right and have no idea how to begin part b.
You have part a correct.
For part b, think about energy.
So since V = U/Q I can set it as (2kλπa)/(a2 + d2)1/2 = U/Q since the Q is the same as the one the ring has I can replace Q as λL since L = 2πa, Q = λ2πa So U = (4kπ2λ2a2)/(a2 + d2)1/2 and U = KE = 1/2mv2, so v2 = (2kπ2λ2a2)/(m(a2 + d2)1/2)
then I take the square of both sides and I get v = (πλa(2k)1/2)/(m(a2 + d2)1/2)1/2
Where d is...?
I think there may be a factor of 2 error.
haruspex said:
Where d is...?
Can you please elaborate on what you mean? I don't know if you are saying that is the speed at d or if you are asking where d is at.
I see it now the (2k)1/2 is actually a (8k)1/2
haruspex is pointing out that you never defined what the symbol d represents.
Yes.
Right, but more importantly that d is not given as part of the question, so should not appear in the answer.
Since d can't be in the solution should I be looking to relate d to a or am I just going about this the wrong way?
I understand the problem is saying that the particle is starting a distance ds, but i still don't understand how that helps me solve the problem. Is ds somehow related to d cause I just don't see it.
It means that you can treat d as zero initially.
So does this mean the answer is just v = πλa(8k/ma)1/2
Yes, but you can simplify a bit more.
v = 2πλ(2ak/m)1/2
Cantspel said:
v = 2πλ(2ak/m)1/2
Looks good.
Thanks for all the help!
