What is the energy lost when a body falls onto a moving cart without friction?
  • Thread starter Thread starter devanlevin
    Energy Lost
In the discussion about energy loss when a body falls onto a moving cart without friction, it is established that the free-falling body reaches a velocity of √(2gh) at impact. Momentum conservation equations are presented, but it is clarified that the y-momentum is not conserved due to an external force from the ground. The total initial energy is calculated as mgh + 0.5MV², and the final energy is expressed as 0.5(m+M)(Uy² + Ux²). The correct approach to find energy lost is to subtract final energy from initial energy, leading to the conclusion that energy lost is Ei - Ef. The discussion emphasizes the importance of correctly applying momentum conservation and energy principles in this scenario.
devanlevin
a cart with a mass of M is moving at velocity V, a body with a mass of m falls onto the cart from a height of H and sticks to it, how much energy was lost (to heat), there is no friction.
i said that, since the mass freefalls, its velocity at the moment of impact is\sqrt{2gh}
the momentum doesn't change so
MV+0=(m+M)Ux
0+m\sqrt{2gh}=(m+M)Uy
is this correct? will the cart have velocity on y axis??
if there is no friction how is Ux<V
then find the total energy at the start, which is mgh+0.5MV^{2}, and subtract it from the energy at the end 0.5(m+M)[Uy^{2}+Ux^{2}]
is this correct
the answer in my book is
Q=mgh+V^2\frac{Mm}{2(m+M}
MV+0=(m+M)Ux
This last equation is not correct. These equations represent the momentum of the masses m and M, but there is an external force in the y direction (from the ground). So the y-momentum is not conserved because the ground prevents the cart from moving in the y-direction.
It's the other way around; energy lost is Ei-Ef
