What is the force on the trailer wall
The discussion focuses on determining the force exerted by unshelled peanuts on a trailer wall to select appropriate composite materials for construction. The trailer dimensions and peanut weight are provided, with an emphasis on calculating sideways forces due to the material's distribution. References to the Janssen equation and hydrostatic assumptions suggest that treating the peanuts as a liquid can provide an upper limit for wall forces. It is noted that for trailers under 10 feet high, this method is practically accurate. Additionally, the abrasive nature of dry granular materials is highlighted, indicating the potential need for protective liners.
Pratap Lingam
Hello All,
I am a semi trailer manufacturer who just started building specialty trailers for various industries. Recently I have been asked to develop a trailer to carry peanuts from the farms and deliver them to ware house. To design the trailer light enough, i have decided to go with Composite panel, but manufacturer wants to know the force of the Unshelled peanuts, so they can suggest the right material for us. I have never done this, so I need help from bright minds like you. Here are the details.
Trailer storage area for peanuts is: 44' L x 102" W x 9' 6" H
Unshelled Peanut weight per cubic feet is: 17.6 lb (approximate)
Unshelled Peanuts are equally distributed inside the trailer. So the force will be downward and sideways. I need to know the force on the sideways, so the right composite panel is used and supported in right places.
Any help is greatly appreciated.
Thank you very much.
Pratap
http://www.inti.gob.ar/cirsoc/pdf/silos/SolidsNotes10HopperDesign.pdf- Section 10.10
That's pretty sophisticated ! It will be quite a job to establish the proper values for all the variables in the Janssen equation 10-9. (This may help ?)
However, from figure 10-7 you can see that the assumption that the material behaves as a liquid ("hydrostatic") at least gives an upper limit for the forces on the walls (fig 4-6 http://udel.edu/~inamdar/EGTE215/Hydrostatics.pdf ).
Likes Nidum
Yes - and for a trailer wall less than 10 ft high it is probably accurate enough in practice .
Note that many dry granular materials are very abrasive and you will sometimes see trailers with throw away polythene liners as protection .
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
