Shaun Harlow
- 2
- 0
I am only aware that the formula has to do with entropy/thermodynamics. I could really use the help on how it applies in physics and what the formula is really about.
Shaun Harlow said:I am only aware that the formula has to do with entropy/thermodynamics. I could really use the help on how it applies in physics and what the formula is really about.
stevendaryl said:In that equation, S is the entropy and E is the energy. In thermodynamics, temperature can be defined as:
\frac{1}{T} = \frac{dS}{dE}
So your inequality just says T \gg 0. So the temperature is well above absolute zero.
Shaun Harlow said:So the inequality is saying that the temperature is above zero? If so, you talk of the "bizarre notion" of a negative absolute temperature that some people infer, but that is not possible correct?
stevendaryl said:That definition of temperature assumes that entropy increases with energy (so T is always positive), which is true for classical thermodynamics, but for systems with a discrete number of states, it's possible for S to decrease with E, which leads to the bizarre notion of a negative absolute temperature.
stevendaryl said:The symbol \gg means "much greater than". So the temperature isn't just positive, it's pretty high.
Negative temperatures are not possible in classical thermodynamics, but there are quantum systems where a negative temperature is possible. A negative temperature means that the entropy goes down instead of up when the system gets more energy.
