What is the ideal thickness for a 304 stainless steel waste water tank?
The ideal thickness for a 304 stainless steel waste water tank constructed from sheet material typically ranges from 1 to 2 mm, with 1.2 mm being common for standard applications. The design should incorporate bracing, especially at the base, to support the weight of the waste material and prevent punctures. For tanks with a square shape, additional reinforcement may be necessary to maintain structural integrity. Manufacturers often provide guidelines and examples for optimal design practices.
  • Understanding of 304 stainless steel properties
  • Knowledge of structural engineering principles
  • Familiarity with tank design and bracing techniques
  • Experience with material thickness considerations in construction
  • Research "304 stainless steel properties and applications"
  • Explore "design principles for waste water tanks"
  • Learn about "bracing techniques for structural integrity"
  • Investigate "manufacturers of stainless steel tanks and their specifications"
Engineers, construction professionals, and anyone involved in the design and construction of waste water tanks will benefit from this discussion.
NeverSayNever
Hi,
I'm constructing a waste water tank of 304 stainless steel plate and I'm not sure what thickness the material should be, the tank is approximately 2750mm x 1500mm x 1750mm
What would the ideal thickness be for the 304 stainless plate and would there be any specific areas I should focus on adding bracing for strength?
ANY help that can be offered is welcome
Do you really mean plate or so you mean sheet, which is likely to be thinner?
For example standard sink units are made from 1.2 mm 304 steel. Stainless tanks are often made from corrugate sheet 1 - 2mm thick. The forming adds stiffness to such thin sheet.
Depending upon your base bearers or floor you might need a thicker bottom.
Galvanised tanks are usually of thicker material.
There are plenty of manufacturers showing their ideas on the net here is a good example.
http://www.mc-integ.com/lists_view.cfm?ID=18
My mistake, it is indeed sheet, the design is supported by legs and my concern is that the pressure of the waste material is going to bare down on the floor etc too heavily and cause a puncture, my background is in design engineering so I'm not really sure where the ideal areas for bracing are, I've no real experience in waste water as my experience in working with stainless steel was purely for decorative purposes
The tank is pretty much a square so I am not really sure where to start, any ideas?
9K
  • · Replies 26 ·
