What is the indefinate integral
  • Thread starter Thread starter sora4ever1
    Integral
The discussion focuses on finding the indefinite integral of tan^7x sec^4x. A suggested method involves using the identity sec^2x = 1 + tan^2x to express the integral in terms of tan x, followed by u-substitution. The integral is computed as ∫ tan^7x sec^4x dx = ∫ tan^7x(1 + tan^2x) sec^2x dx, leading to the result of (tan^8x/8) + (tan^10x/10) + C. Participants express uncertainty about potential errors in the solution, but ultimately confirm its correctness. This highlights the importance of understanding integration techniques in calculus.
sora4ever1
:confused: :confused: i have this question can anyone help me please thx.
what is the indefinate integral of tan^7xsec^4x goodluck.
What have you tried so far?
:redface:
i am not yet to that grade lvl yet so that is why i want some one to post this explaing how to do it and little back ground to this thanks :biggrin:
Basically, I believe you must simply save a factor of \sec ^ 2 x
and use \sec ^ 2 x = 1 + \tan ^ 2 x to express the remaining factors
in terms of \tan x. Next, simply substitute with respect to \tan x.
(I think it's called "u"-substitution in some texts).?
As you should already know, :shy:
\frac{d}{dx} \tan x = \sec ^ 2 x
*Here's that method, put in action :smile: :
\int {\tan ^7 x\sec ^4 x\,dx} = \int {\tan ^7 x\left( {1 + \tan ^2 x} \right)\sec ^2 x\,dx} =
\int {\tan ^7 x\left( {1 + \tan ^2 x} \right)\,d\left( {\tan x} \right)} = \boxed{\frac{{\tan ^8 x}}{8} + \frac{{\tan ^{10} x}}{{10}} + C}
!It is very likely that somewhere I made an error!...:frown: :frown: :frown:
Somewhere...some silly error :rolleyes:
thx a lot.
No, this is correct :smile:
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
