What is the is the rise in temperature of the rock
The discussion revolves around a physics problem involving the temperature rise of a rock and water after the rock is dropped into the water. The original poster is confused about the energy conservation equation provided by their teacher, which states that the potential energy of the rock converts into heat for both the rock and the water. The teacher emphasizes that the initial temperatures of the rock and water are crucial, as they determine how heat is exchanged between them. If the rock and water start at different temperatures, the heat transfer will vary based on their specific heats. The conversation highlights the importance of correctly applying the principles of energy conservation in thermal dynamics.
Sheldinoh
My Physics teacher gave us a quiz problem and I don't understand it really how he got his answer. Can you please give me your answer and an explanation for the answer Thanks. Here is the question:
A .5 kg rock is dropped from a height of 20 meters into a pail containing .6 kg of water. The rock has a specific heat of 1480 and the water has a specific heat of 4186. What is the is the rise in temperature of the rock and water ?
Show what you have tried already.
I think it is:
mgh(energy of fall ) = mcT + mcT
My teacher says its:
mgh + mcT = mcT
.In terms of energy changes PE changes to KE and then to heat in both the water and the rock.It is not necessary to calculate the KE so go straight to your equation which is the correct one.Make sure you plug in the right values for m and c.
Thanks for agreeing with me. Could you help me out now with making my physics teacher agree with me. He says that you add the energy of the rock with the heat from the rock to equal the heat of the water. mgh+mcT(rock)=mcT(water). I think it is wrong but I have no clue how to explain it. Do you know how.
The impression gained from your question was that the rock and water were both at the same temperature at the start. Let us assume they are not.
If the rock were colder then it would gain some of its heat energy from the heat energy of the water and if the water were colder it would gain some of its heat energy from the heat energy rock.If they were at the same temperature, which is what I assume from your question,then both would gain heat energy from the PE only and both of them would heat up.
