What is the Kinetic Energy of a Block on a Pulley System?
The discussion focuses on calculating the kinetic energy of a block in a pulley system, considering friction. The initial potential energy of the 6.00 kg block is calculated as 117.6 J. The frictional force acting on the 8.00 kg block is determined to be 19.6 N, leading to a work done against friction of 39.2 J. After accounting for friction, the kinetic energy is found to be 78.4 J, which is then used to calculate the speed of both blocks as 3.35 m/s. The importance of considering both blocks in the kinetic energy calculation is emphasized.
marckc22
Consider the system shown. The coefficient of kinetic friction between the 8.00 kg block and the tabletop is ųk = 0.25. Neglect the mass of the rope and of the pulley, and assume that the pulley is frictionless. Use energy methods to calculate the speed of the 6.00 kg block after it has descended 2.00 m., starting from rest.
http://img154.imageshack.us/img154/3854/image1nr8.jpg
i have no idea. help me.
someone help me please...
welcome to PF. Do you have any ideas? Hint: the kinetic energy of the two blocks comes from the potential energy of the falling block.
So, if there were no friction:
mgh=1/2(m+M)v^2 where m=6Kg, and M=8Kg but there is friction, do you know how to compute work done by friction?
Normally we ask for some thoughts or at least posting some eqns on a problem, before anyone will help.
this is what i did:
first i solved for the potential energy
PE = mgh = 6(9.8)(2) = 117.6 J
then i solved for the force done on the block
F = ų*mg = (0.25)(6)(9.8) = 14.715 N
then i solved for the work done on the block
W = (14.715)(2) = 29.43
then i solved for the kinetic energy
KE = PE - W = 117.6 - 29.43 = 88.17 J
and lastly i solved for the speed
V = (88.17/0.5(6))^-2 = 5.42 m/s
am i right?
Your on the right track
$ U_p=2*6*9.8=117.6 J$
But you've used the wrong mass in the friction force
$ F_f=0.25*8*9.8=19.6N\\<br /> W=2*F_f=39.2 J\\<br /> E_k=U_p-W=78.4J\\$
Your final line also contains a mistake as you have assumed that the 6kg blosk is the only object with kinetic energy, whereas both object have the same velocity.
$ E_k=\frac{1}{2}(m+M)v^2=7v^2\\<br /> 7v^2=78.4 J\\<br /> v=\sqrt{\frac{78.4}{7}}=3.35ms^{-1}$
thanks a lot!
