What is the length of the red line in this geometry problem?
  • Thread starter Thread starter Hygelac
    Geometry
The discussion focuses on finding the length of a red line in a right triangle geometry problem. The height of the triangle is given as 20 feet, and the base length exceeds 58 feet. Participants suggest using similar triangles to establish a ratio: x/6 = (58+x)/20, which simplifies the problem. The original poster struggles with the Pythagorean theorem, indicating a preference for the similar triangles approach. This method is deemed more straightforward for solving the problem.
Hygelac
First off, my attached image will make things make sense. I have a triangle (with a 90 degrees corner), I know that the height is 20' and that the length is more than 58'. I need to find out what the length is to the left of the 6' height mark (trying to find the length of the red line). Can anyone help me?
Mathematics news on Phys.org
I'll call the distance to be found x
Use similar triangles the 20 is to the 6 as x+58 is to x. From here you can solve for x.
Excuse me for being dumb, but I still can't figure it out.
c^2 = 20^2 + (58+x)^2 gives me really hard to work with numbers, I don't think I'm doing it right.
Don't use the Pythagorean theorem, us "similar triangles". Since the two triangles, the small one on the left and the large triangle, have the same angles, they are similar and their sides have the same ratios: x/6= (58+x)/20.
That's much easier to solve!
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
