What is the limit of the solution curve as x approaches infinity?
The discussion revolves around the limit of a solution curve for the differential equation dy/dx = y - 2y^2, particularly as x approaches infinity. The original poster presents a specific initial condition, (0, 0.25), and explores various potential limits of the solution.
  • Participants discuss the implications of the initial condition on the limit of the solution as x approaches infinity. There are attempts to integrate the differential equation and analyze the behavior of the solution curve. Questions arise regarding the significance of the constant of integration and its effect on the limit.
Some participants have provided insights into the nature of equilibrium solutions and the stability of those points. There is a recognition that the limit may be influenced by the initial condition, and while some participants suggest specific values, there is no explicit consensus on the final answer.
Participants note the presence of multiple answer choices and the potential for confusion regarding the integration process and the role of the constant of integration. The discussion reflects uncertainty about how the initial condition interacts with the limit as x approaches infinity.
cokezero
HELP! limit and differentials
1. i can't seem to figure this out...
if the differential equation dy/dx= y-2y^2 has a solution curve y=f(x) contianing point (o, 0.25) then the limit as x approaches infinity of f(x) is
a)no limit
b. 0
c. 0.25
d. 0.5
e. 2
he problem statement, all variables and given/known data
2. dy/dx= y-2y^2
3. i think it is no limit
integrate( dy/(y-2y^2)= dx)
it is no limit but do you need help solving the integral? also the integral of that doesn't have (0,0.25) but it has (0.25,0), is that what you meant?
no i have the integral down f(X) becomes y= 1/(e^-x + 2) +C; now the limit of f(x) without the c value is 1/2 which is an asnwer choice; but if i take the limit with c , which is -1/12 b/c the initial condition given is (0, 1/4) the limit becomes .41666667; this however is not an answer choice given...
so when taking the limit of the f(X) should i include the c value...does it matter?
f(x) pass in (0, 0.25) , find the value of c, then do the limit again.
I suspect that actually finding y was not the point of this question.
dy/dt= y- 2y2= y(1- 2y)= 0 when y= 0 or y= 1/2. That is, the differential equation has y= 0 and y= 1/2 as constant (equilibrium) solutions. If y< 0 then 1- 2y is positive so dy/dt is negative and y is decreasing. If 0< y< 1/2 then both y and 1-2y are positive so dy/dt is positive and y is increasing. y= 0 is an unstable equilibrium point. If 1/2< y then 1- 2y is negative so dy/dt is negative, dy/dt is negative so y is decreasing. y= 1/2 is a stable equilibrium point. If y(t) is positive for any t, then y(t) will go to 1/2 as t goes to infinity.
For this problem y(0)= 0.25> 0 so y(t) goes to 0.5 as t goes to infinity. The answer is (d).
  • · Replies 18 ·
  • · Replies 24 ·
