What is the magnitude of the net acceleration of the object
The discussion focuses on solving physics problems related to net acceleration and tension in cables. The first problem involves calculating the net acceleration of an object subjected to two forces, resulting in an acceleration of 3.5 m/s² after correctly applying vector addition. The second problem addresses a weight suspended in equilibrium by two cables, requiring the use of vector addition to determine the tension in the second cable. Participants emphasize the importance of free body diagrams and understanding the equilibrium condition, leading to a correct tension calculation of approximately 350 N. Overall, the thread highlights common challenges in applying Newton's laws and the benefits of visual aids in problem-solving.
tsoya
im studying for a test, unfortunately i seem to be having difficulty with the simple problems, so i decided to try some practice problems:
1. two forces, each of 100N, act on an object having a mass of 40 kg. What is the magnitude of the net acceleration of the object if one of the forces is directed upward and the other is to the left?
the answer it says is 3.5 m/s^2. i know net external force=mass x acceleration, so i tried figuring out the net external force and I think that's where I get confused. because force is mass times acceleration? ug i don't know. can someone help please?
oh thank you so much! i got it now, square root of (100^2 + 100^2) then divide by 40. may i ask another one?
a 250-N weight is suspended in equilibrium by two cables. one cable applies a horizontal force to the right. the other cable applies a force upward to the left at an angle of 45 deg. to the negative x-axis. what is the tension in the second cable? answer: 350 N
-how do you incorporate the first cable into figuring out for the second? I've tried solving this a couple of days ago, and still can't. any type of hint would be helpful!
First find the net force by adding the two force vectors to get their resultant. (Remember to use vector addition.) Then use Newton's 2nd law to find the acceleration.
i posted another problem in the first post if anybody is willing to offer any help =)
tsoya said:
a 250-N weight is suspended in equilibrium by two cables. one cable applies a horizontal force to the right. the other cable applies a force upward to the left at an angle of 45 deg. to the negative x-axis. what is the tension in the second cable? answer: 246 N
Hint: Consider the vertical components of the forces. Since the object is in equilibrium, the net force on it must be zero. (Note that the first cable doesn't contribute to the vertical forces.)
Ok, if we just consider the vertical components we can effectively ignore the horizontal cable as Doc Al said. Now, what force(s) are acting to pull the weight down and how big is this force?
gravity is pulling it down (9.8, so total force is 250 N?)ok the answer is given to be 350, is that right?
Nearly right, what is the equation of force (one of Newton's laws)?
force= mass x acceleration
Yes, so what is the total force acting down?
25.5 kg x 9.8 m/s^2= 250 N
Yes, so as the system is in equilibrium that force must be balanced by an upward force. However, this upward force can only act through the angled cable. Draw a free body diagram, showing the weight, the downward force, the required upward force acting straight up and the angled wire.
oh is this correct?:
250/(cos45)
i get a bit higher than 350 though, 353.55
Yes, that is the answer which I got.
thank you very much for all of your help =)
No problem. For these types of problems I suggest drawing a diagram as it makes things a lot simpler.
