Calculating the Mass of Saturn Using Orbital Data
  • Thread starter Thread starter Fysicsx
    Mass Saturn
The discussion centers on calculating the mass of Saturn using Titan's orbital data, specifically its 16-day orbital period and a radius of 1,222,000 km. The user initially misapplied the formula for orbital period, incorrectly dividing the radius by two. The correct approach involves using the full orbital radius in the calculations. The gravitational constant is confirmed as 6.67e-11 m^3*kg^-1*s^-2. The user acknowledges the mistake and expresses gratitude for the assistance.
Fysicsx
titan, a moon of saturn, has a 16 day orbital period and an orbital radius of 1,222,000 km. what is the mass of saturn?
my attempt:
t = 2*pi*r^(3/2)/sqrt(g*m)
t = 16 days = 1,382,400 s
r = 1,222,000/2 km = 611,000,000 m
1,382,400 = 2*pi*611,000,000^(3/2)/sqrt(6.67e-11*m) => m = 7.065e25 kg
the answer should be 5.6e26 kg, what am i doing wrong?
my attempt:
Hello Fysicsx. Welcome to PF !
Where does the following equation come from?
t = 2*pi*r(3/2)/√(g*m)
What is g in this equation?
hi sammys,
thanks for the warm welcome
f_g = g*m_1*m_2/r^2 (law of gravitation)
v = sqrt(g*m/r) (circular orbit)
v = 2*pi*r/t
t = 2*pi*r/v = 2*pi*r*sqrt(r/(g*m)) = 2*pi*r^(3/2)/sqrt(g*m) (circular orbit)
g is the gravitational constant 6.67e-11 m^3*kg^-1*s^-2
Fysicsx said:
hi sammys,
v = 2*pi*r/t
You divided r by 2.
Solve this for r, not v : v = sqrt(g*m/r)
oops that was careless lol. thanks for your help, sammys.
