What is the mass of this object?
  • Thread starter Thread starter chengbin
    Mass
A net force of 200N is applied to an object, changing its velocity from 30km/h to 20km/h in 2.3 seconds, leading to an acceleration of -1.2m/s². The initial calculation for mass was incorrect, with one participant arriving at 199kg using the formula m = F/a. However, the correct mass should be approximately 170kg, as confirmed by recalculating to 167.8kg. There is speculation that the answer key may have a typo, mistakenly stating 170g instead of 170kg. Accurate calculations are essential for determining the correct mass in physics problems.
chengbin
A net force of 200N is applied to an object, causing its velocity to change from 30km/h to 20km/h in 2.3s.
What is the object's acceleration? What is its mass?
I got the correct answer for acceleration (-1.2m/s^2), but I'm having trouble with finding the mass.
I'm getting 199kg (m = 200N/1.2m/s^2), but the answer key says 170g. How is that correct?
200/1.2 does not equal 199.
The answer should indeed be about 170kg.
Check your calculations again.
Thanks.
Apparently I can't use my calculator properly.
I guess 170g is probably a typo in the book.
they probably meant 170kg.
I got 167.8kg, which approximated to two significant figures gives indeed 170kg.
