What is the minimum force needed to make a brick topple in a moving train?
To determine the minimum force needed to make a brick topple in a moving train, the mass and dimensions of the brick are crucial, with a mass of 50 g and dimensions of 10 cm x 8 cm x 6 cm. The brick is positioned on a rough floor that prevents sliding but allows toppling about a 10 cm edge when the train brakes suddenly. The discussion involves calculating the minimum couple required for toppling and the minimum deceleration of the train that causes this effect. The coefficient of static friction is essential to prevent sliding, and the torque can be calculated by identifying the axis of rotation and summing the torques around that point. Ultimately, the problem was resolved by focusing on the axis of rotation and the torques involved.
Omar.Castillo
A brick of mass 50 g is placed on a level floor inside a moving train. The dimensions of the brick is 10cm*8.0cm*6.0cm. It is placed with one of its 10cm*6cm faces on the floor so that the 6.0 cm edges are parallel to the direction of motion. The train is braked suddenly. Assume that the floor is rough enough to prevent sliding, but allow the brick to topple about a 10cm edge. Find the minimum couple required to makethe brick topple about the 10 cm edge?
I know that the coefficient of static friction is proportional to the normal force. So must I equal the normal force to the coefficient of kinetic friction to get the answer?
After that question the next one is to find the minimum decelaration of the train that makes the brick topple about the 10 cm edge. and determine the minimum value of the coefficient of static friction between the brick and the floor that prevents the sliding
I cannot imagine how to get the torque force without using fictional forces any way to get it without it?
Got it
Never mind guys I finally got it after hard 3 hour work, thanks anyway for at least looking at it
All you do is identify the axis of rotation (the front edge!)
and sum the torques around that axis.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
