What is the minimum stopping distance
To determine the minimum stopping distance for a 6000 kg load on a truck, the maximum horizontal force of 8000 N is crucial. Using the formula F = ma, the acceleration can be calculated, leading to the necessary kinematic equations for stopping distance. A diagram is recommended for clarity in visualizing the problem. The calculated stopping distances vary, with one participant arriving at 150 m, while another suggested 156 m, indicating potential calculation discrepancies. The discussion emphasizes the importance of correctly applying physics principles to solve the problem.
emily69_420
I have gotten stuck on this problem because I can't figure out the formula to solve it so really all i need is the formula. I've read the book but i have this class online and have no instructor...please help if you can.
Heres the Problem:
A load of steel with a mass of 6000 kg rests on a flatbed of a truck. It is held in place by metal brackets that can exert a maximum horizontal force of 8000 N. When the truck is traveling 20 m/s, what is the minimum stopping distance if the load is not to slide foreward into the cab?
F = ma.
Here's a start. You know the F is 8000N. You know that the weight of the load from gravity (which has a=32 ft/sec sec) is 6000N. So what is the acceleration that results from a force of 8000N?
Carl
8000/6000=a?
You'll find that it works really well to draw out a diagram on this one. Remember that the block is also traveling at 20 m/s.
Ok i think i figured it out but i am getting two different answers when i do the problem...i got 150 m and 156 m can someone tell me if i might be close to the answer?
F=ma
You have the mass of the load already so you can find the maximum acceleration
Find the maximum acceleration you can have without the straps breaking. Then calculate the stopping distance using your kinematics equations.
I get 150 m as an answer
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
