What is the newest installment of 'Random Thoughts' on Physics Forums?
    Random Thoughts
11,071 replies · 760K views
Wrichik Basu said:
The reason why some people recommend putting Android phones in aeroplane mode or to shut them down completely is so that the battery can draw as much current as possible and charge itself fast.
When the charger is plugged in, the Android system sends a broadcast (a system-wide message that any app can listen to) with the action android.intent.action.ACTION_POWER_CONNECTED. Several apps will listen for this broadcast, and as soon as it is received, they will activate their routines and start some battery-intensive work. For background work, we use Android WorkManager, which has an option to start a work when the charger is connected. Therefore, in most phones with a number of heavy apps, when you plug in the charger, a part of the charger current will be used behind the system rather than charging, and charging becomes slow.
Most of the apps that activate when the charger is connected are doing work over the internet. Engaging aeroplane mode disconnects internet, and those apps are paused due to lack of connectivity. I haven't tried, but probably just turning off mobile data and WiFi will probably have the same effect as aeroplane mode. And aeroplane mode with WiFi connected will probably defeat the purpose.
If you shut down your device, you are making sure that all the current delivered by the charger can be utilized to charge the battery.
But aeroplane mode does not make a difference if your phone is switched off. Switching off means it's completely off. So, all cell services are suspended automatically.
Shutting down is probably more effective than aeroplane mode alone because aeroplane mode still allows apps to run, and that will consume some battery. But the number of apps that do not require internet access at all is steadily decreasing, so maybe after some time, aeroplane mode will suffice. It also depends on how well the app is written. Honestly, without data, it is difficult to judge which is more effective.
Personally, I never turn off my devices/engage aeroplane mode while charging. I just don't like it, as I am not sure how effective those methods actually are due to lack of proper statistical data. If your device supports fast charging, then there is no need to do any of these.
Thank you. I have only one data point: airplane mode decreased time significantly; airplane mode and turning it of simultaneously did not. Will keep experimenting and will let you know if you're interested. I mean I can't really control for other factors but data may still be worth something.
Nowadays, the number of apps which can work without internet connection is significantly less, and the majority of apps which start background jobs specifically when the charger is connected are doing something over the net (and that is why they are supposed to consume more battery and turn on when charging only). When you turn on aeroplane mode, those apps are prevented from working, and less CPU and power are consumed, which, in turn, charges the battery faster.
As I said, aeroplane mode has no role if the phone is switched off, but switching off should still allow the device to be charged faster as the system and apps are not consuming any power.
Hornbein said:
I very much doubt that. I've been around a lot of this sort of thing and musicians like this always seem to start gigging at a young age. They usually don't go to music school. Those who do quit before they graduate (Miles Davis, Steve Vai, Rick Wakeman) and turn pro. People with degrees almost never become working musicians. They teach instead.
So I looked up Yes. Sure enough, bassist Chris Squire dropped out of high school and started gigging at age 17. Guitarist Steve Howe started performing at age 14 and went full time at 18. I think neither ever took lessons. Bill Bruford, age 17, "a few lessons." Jon Anderson, dropped out of school at 15, started gigging at 18 to get out of manual labor.
The exception is keyboard players. The music for piano is so difficult that you need to take lessons starting young as three to six years old. So did Eddie van Halen (who introduced keyboard style "tapping" to the guitar).
The outlier is guitarist Pat Metheny, who earned a degree from Berkelee. But I was there at the time and everyone knew he was the star of the school from the beginning. He was the Chosen One and wasn't in any hurry. Hiromi Uehara got a degree too and made it big but East Asian people have a different way of doing things.
I went to music school for a year but it was a waste. I would advise young musicians to sit down with recordings and copy them exactly. Then gig as much as you can. That's how everyone I know who made it did it. That wasn't my style so I got out quick.
People like Yes are obsessed with music, work on it all the time, and maybe can't do anything else. Saxophonist Dave Liebman said, "I don't know anyone who didn't work his butt off. Except maybe Mozart. You are not Mozart."
Thanks for the research and for being direct and not, er...roundabout ;).
I somehow have a driver for some hardware that , AFAIK, has never existed in my PC.
"Common knowledge" is often not terribly knowledgeic : yours is no disgrace ;)
So yesterday it rained pretty hard. One of the windows on our house has always had some issues with water leakage and it leaked again yesterday. So today I took a look to see what was going on with it. I noticed some cracking in the caulk and since it was covered in mold, I decided to remove it and completely replace it. That's when I discovered this.
As you can see there are significant gaps between the window and the brick. The window trim should be sitting on top of the brick and NOT behind it.
The best I can figure is that the moron who installed it put the trim on before installing the window and when it wouldn't fit correctly, they chipped away the brick until it did - they even managed to fracture the brick on the right side, providing even more opportunities for water to get in the house.
Then, they layered caulk in the gaps (some as much as 1/2 inch) until it was filled in. Not only that, they also had the window installed so low that the weep hole on the left side was covered. No problem! They just drilled a new hole in the trim above the brick line.
This was a third floor window. I checked the one on the second floor and it had the same dumb installation. I haven't checked all 20+ windows on our house but I haven't seen it elsewhere - yet.
Some people should never be allowed near a construction site. :oldmad:
  • Sad
No automatic reservations at the First Czech Inn.
  • Haha
Another inspection of my windows this morning showed that all of the windows above the first floor were installed like my previous post. The two that you could walk past and easily check, were installed correctly. I even found one above my garage that was never even caulked and had a gap the size of a half dollar. So, for over 25 years, water has been pouring between the plywood and brick every time it rains.
  • Sad
Caveat emptor. You know it's deliberate, intentional fraud, but well outside even the RICO statute of limitations.
@ergospherical I thought that was Photoshopped, but Google Images shows it's a real brand with lots of products. Sheesh! :oldeyes:
Though Borg's problems are with the related caulk...
The Russian word for 'how' sounds like that. Plus, it's often the first word in the sentence. It's pretty funny listening to them sometimes when they're asking questions.
Keith_McClary said:
The Grace Kitchens Cock Flavoured Soup's ingredient list is a bit surprising. It explains that it contains no chicken, rooster, or any type of poultry.
That's nutty. (Oh, and the link didn't work for me)
Is it possible for someone to find your phone # from a pic you post somewhere or by just making a post from your phone? I got a WhatsApp message from a UK number ( country code 44) claiming we had met in Singapore ( never been there) where we exchanged numbers.
I am a bit paranoid over two recent scam attempts so I wonder if that's what this was.
Ibix said:
Most probable is some girl gave a creepy dude a fake number which happened to be yours, surely?
Well, but it is supposedly a woman that contacted me; how did ' Lisa' end up with my number? At least she has not asked me for any questionable info. As long as she does not, I guess I can just go along. But it's still troublesome because modern scams are much more sophisticated than the old " I am an African prince and my money is being held.." kind. Edit: And the phone number may have been spoofed, so not sure she's in or from the UK.
Why go along with anything? Just ignore. You don't owe anyone an answer. If you want to be nice you could just text back "you've got a wrong number, I've never been to Singapore".
ergospherical said:
I can beat that. In a Tokyo barber shop was a big can of Cock Grease.
Yes , I agree , I will just end it at that.
I just received a new like on a post I made in October, 2003.
That must be a record for me.
I'll be back here on 2039 to upvote this comment .
10 Years after Apophis? Unlikely. :cool:
  • Haha
Is that another one? Is that too about too few registers for dates?
Is that the asteroid? I thought it had changed course?
Not quite for ' Lame Jokes' but
It's complicated, I think. AFAIK it will pass by, except it will pass through a certain area a few years earlier. Something like that.
I understand even if it veers of its path by a very small amount now, it will be hundreds of miles of. Is that its name ' apoph'?
