What is the optimum pitch angle for ceiling fan blade design?
  • Thread starter Thread starter Pang Chun Wai
    Design Fan
The discussion centers on designing an efficient ceiling fan blade with an airfoil section, tapering, and twisting. There is skepticism about the effectiveness of airfoil designs compared to flat blades, as traditional ceiling fans typically use broad paddles that do not spin fast enough for narrow blades to be beneficial. However, one participant acknowledges that airfoil sections can be practical, especially when starting with a wider chord that tapers down. The conversation highlights the need for further insights and responses from others in the forum. Overall, the quest for the optimum pitch angle remains a key focus in achieving high efficiency in ceiling fan blade design.
Pang Chun Wai
For the final year project that i am doing, I need to design a high efficiency ceiling fan blade with airfoil section, tapered and also twisting. Can anyone tell me how can i obtain the optimum pitch angle for different section of my ceiling fan blade?
I doubt that an "airfoil section" will make much difference over a flat angled blade in a ceiling fan situation. Most use very broad "paddles" as opposed to "propellors" such as an aeroplane would have. They just don't spin fast enough to use a narrow blade. It's hard to impart an airfoil shape to a fat one. I might be missing something here, though, so wait for a response from someone else.
no one is replying me...zzzzzz.. tis article have show that the airfoil section for ceiling fan blade is practical
I stand corrected, and am actually quite impressed by those figures. In my defence, I didn't realize that the blades started with a 6.5" chord and then tapered down. I was envisioning about half of that.
Hang in there; somebody is eventually going to show up.
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
