What is the orientation of the vector of friction?
  • #226
JrK
139
the original friction question has been settled
If I have the right to add that case where I think your method doesn't work, if not the moderator can delete that message ? I imagine a circle that I blowed up (inflate), like a balloon but it is a circle. The radius of the circle increases more and more but the center of the circle is fixed to the ground. I drew the device at start and at end:
An enlargement to watch there is no friction:
I used your method (look at the dot of contact, they are at the same place):
Enlargement:
I replace the circle at the center just to see the magenta length:
Enlargement:
When I place the walls at the exact position, I need to count the movement of the magenta length. But there is no green length, the last drawing shows a difference of position of the dot of contact but look at the difference of length at the end of the walls, it is the same distance. I'm not sure at 100% there is no friction between the circle and the wall when I blow the circle, but the images seem to watch that.
The distance measure of friction is small but not exactly at 0, I measured: 0.03 but the distance calculated of the magenta length is 0.19, I can compare the lengths with the 2 following images at the same scale:
  • Sad
Likes Motore
  • #227
A.T.
2,132
... inflate ...
What does this have to do with your original scenario? It was rigid bodies only.
  • #228
JrK
139
But the method is not universal ? it works for some examples not for others, so how to know if for an example it works or not.
  • #229
A.T.
2,132
The universal method is integrating force dot relative velocity.
Likes jbriggs444
  • #230
A.T.
2,132
For me I don't have the right to do that:
This is a trivial coordinate transformation to the rest frame of the wall.
  • #231
JrK
139
I understood the problem (at least mine): the wall rotates around A0, but the wall doesn't rotate around the circle ! look the 2 positions:
If I place the circle at the same center:
And if the wall doesn't rotate around the circle, I need to correct its orientation just after rotate the group. So, the image :
is correct with your method.
  • #232
A.T.
2,132
If you do this, then it's not a mere coordinate transformation. You are changing their relative orientation and thus the physical situation.
  • #233
JrK
139
Are you agree that the wall doesn't rotate around the circle ?
  • #234
A.T.
2,132
Depends on what "rotate around a circle" means.
  • #235
JrK
139
When you are fixed on the circle (you can see the wall), you see no modification of the orientation of the wall. You are fixed at the dot 'f' on the circle:
When the circle moves in translation and when in the same time the wall rotates around A0, you see the same orientation of the wall.
  • #236
A.T.
2,132
In your original scenario the wall changes orientation in the rest frame of the circle.
  • #237
JrK
139
Yes, it is because I think with the dot of contact but I don't have the right...
Have you the equations of what I need to integrate to measure the length of friction ?
  • #238
A.T.
2,132
Yes, it is because I think with the dot of contact ...
It has nothing to do with their contact point. The wall rotates while the circle doesn't, so the orientation of the wall relative to the circle changes.
  • #239
JrK
139
Have the equations I need to integrate ?
  • #240
A.T.
2,132
The 2nd equation in this section (v is the relative velocity of the materials in contact)
https://en.wikipedia.org/wiki/Work_(physics)#Mathematical_calculation
But in your specific scenario you can derive an analytical formula for the slip distance (sum of green and violet lines in post #179), and then multiply it by the constant force of friction.
  • #241
JrK
139
I have a question about the direction of the graphical method. I built all the drawings with the final position back to the initial, why ? (at the beginning of the thread I done that, without think of the direction) the true direction is from the initial position to the final. If I drew from the initial to the final I have less than d2, it is worst: I have less than d2. With basic examples, it is easy and from initial to final or the reverse it is the same result, here not at all.
  • #242
A.T.
2,132
If you get different diagrams depending on what part you draw first, then that's more a problem with your consistency, rather than physics.
Related Threads on What is the orientation of the vector of friction?
  • Last Post
  • Last Post
14K
  • Last Post
  • Last Post
  • Last Post
