What is the Point of Zero Electric Field?
The discussion revolves around determining the point at which the electric field is zero between two charges, q1 and q2, with specified values. Participants are exploring the relationship between electric forces and fields in the context of electrostatics.
  • Participants discuss setting the forces equal to each other to find the point of zero electric field. There are questions about the correct setup of equations and the role of a hypothetical test charge. Some participants express uncertainty about the algebra involved and the implications of charge signs.
There is ongoing exploration of the problem setup and mathematical relationships. Participants have provided guidance on the correct approach to equate forces and the importance of charge signs. Multiple interpretations of the problem are being discussed, particularly regarding the location of the zero electric field.
Participants are working with two charges of opposite signs and are considering the implications of their magnitudes and positions. There is mention of specific values for the charges and the distance between them, which may influence the calculations.
Keithkent09
In the figure below (q1 = -2.3 µC, q2 = 6.80 µC), determine the point (other than infinity) at which the electric field is zero. (Figure is attached)
E=k*Q/r^2
F-k*q_1*q_2/r^2
F-Q*E
I thought about finding where the force is zero and then the electric field would be zero because of F=Q*E. But I did not think that that was correct.
Hi Keith! :smile:
(try using the X2 tag just above the Reply box :wink:)
No, that's fine … F = qE, so they're zero together. :smile:
(btw, i think it's usually little q for charge, except big Q for the charge of a black hole :wink:)
Alright I get that part.
So then I set the two forces equal to each other and k*q_1*q_2/x^2=k*q_2*q_1/(d-x)^2
Is that the correct set up?
erm :redface: … what about q (or Q) ? :wink:
Um you mean the F=qE part?
If that is the case then the q is just the overall charge right and I am given two qs so I am not sure what that translates as...
Keithkent09 said:
…the q is just the overall charge right and I am given two qs so I am not sure what that translates as...
No, q isn't "the overall charge", it's a hypothetical "test" charge.
Your …
… cancels out to give 1/x2 = 1/(d-x)2.
You need the forces on a hypothetical charge q to be equal and opposite.
Yeah I did that earlier and I got x to be .5 using d=1 meter.
However this answer is not correct. Was my algebra just bad or is there something more to the problem. Sorry I am just having a tough time.
That's because your k*q_1*q_2/x^2=k*q_2*q_1/(d-x)^2 is wrong.
You need the force on q from q1 to be equal to the force on q from q2
So that leaves me with q_1/x^2=q_2/(d-x)^2?
Yes. :smile:
Alright good. I got x=.57. This does not seem to be the right answer and I think this leaves me to be in between the two charges instead of to the left of them. What is the next step or did I do something incorrectly again?
ah, they have opposite charge, so the equilibrium position will be outside, so you need to use d+x instead of d-x. :smile:
Do I include the negative signs for the charges or is it the absolute value of those charges I cannot remember?
Good morning Keith! :smile:
(just got up :zzz: …)
To find the direction of a force, you must include the sign of the charge. :wink:
  • · Replies 16 ·
