I What is the pressure gradient towards the centre of a large planet?
The pressure gradient towards the center of a large planet, such as Earth, reaches its maximum due to the weight of the overlying material, even though the gravitational field falls to zero at the center. The pressure curve is influenced by the radial distribution of density, which affects the pressure calculation. While the formula for pressure involves integrating density and gravitational force, the exact bounds for integration remain unclear. As one approaches the center, the addition of mass to the overlying material decreases, leading to a minimum pressure gradient. Overall, the pressure does not ease off but rather reflects the cumulative weight of the material above.
kevindin
Given that the gravitational field falls to zero at the centre of a large body (e.g. the earth), what happens to the pressure curve? (Assuming no effects due to high temperature.) Does it ease off too? What would the curve look like and what would the formula be?
Astronomy news on Phys.org
It reaches its maximum, as the pressure is the result of the weight of the overlying material.
That I can't answer. Perhaps someone here can provide the math.
Likes BillTre
Simple rules
Pressure is
P=∫ρgdr
Where g is
g=Gm/r2
and
m=∫4πr2ρdr
Hm, cannot figure out an easy way to place the bounds on your ∫.
There would be no effects due to high temperature. What matters is the radial distribution of ρ.
High temperatures have an effect on the radial distribution of ρ.
As you approach the center, less and less mass is added to the already overlying material. Hence the pressure gradient will be at its minimum.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
