What is the purpose of glacial acetic acid in the oxidation of benzhydrol?
  • Thread starter Thread starter Delta what
    Oxidation
Glacial acetic acid is used in the oxidation of benzhydrol to benzophenone primarily as a solvent and to provide an acidic environment that facilitates the reaction. It helps stabilize the dichromate complex and enhances the oxidation process by maintaining the necessary pH. Sodium dichromate serves as the oxidizing agent, converting benzhydrol into benzophenone by removing hydrogen atoms. The role of NaHCO3 in the extraction process is to neutralize any remaining acid, ensuring efficient separation of the organic layer. Understanding these chemical interactions is crucial for grasping the overall reaction mechanism.
Delta what
In a lab we oxidized benzhydrol to produce benzophenone. We use glacial acetic acid and sodium dichromate dehydrate to oxidize the benzhydrol. Then we set up the first extraction with water and CH2Cl2 and the second with NaHCO3 and CH2Cl2.
I am trying to figure out what all of the chemicals used are doing.
Especially what the glacial acetic acid is doing?
I am also not quite getting the purpose of the NaHCO3.
I believe that the dichromate is a catalyst that produces a complex with the benzhydrol.
I can't figure out what the acid is doing. My major barrier is that I thought that the lab was trying to remove the hydrogen from the benzhydrol (oxidize it) and wouldn't the acid get in the way of this since it is all to willing to give up its proton (I am guessing more so then the benzhydrol).
[PLAIN]http://://o.quizlet.com/mXl.vLVhNjF3Y6JD7WMDyg_m.png
Hint: converting an alcohol to a ketone is just an oxidation.
Totally get that this conversion is oxidation. I was wondering why I would put something in the reaction put that would be more likely to undergo a loss of a proton over the alcohol. In another experiment we utilized glacial acetic acid and NaOCl. The purpose of the acid there is to react with the OCl making the hypochlorous acid that then undergoes an addition reaction with the alcohol. Then the alcohol hydrogen is taken by water and then the carbon's hydrogen is taken by another water. Then the chlorine leaves and a ketone is formed. I am still not getting the dichromate and glacial acetic acid's relation.
If it is an oxidation - does the dichromate play a role of a catalyst?
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
