What is the purpose of the fourth satellite in GPS navigation?
  • Thread starter Thread starter denni0302
    Gps Satellite
The discussion revolves around the role of the fourth satellite in GPS navigation, particularly its necessity for correcting timing errors in the receiver's clock. The original poster expresses confusion over various explanations found in sources, including Wikipedia, regarding how the fourth satellite contributes to accurate positioning.
  • Participants explore the concept of pseudorange and its relation to the actual distance from the satellite. They discuss how the fourth satellite's data is used to correct the receiver's clock and question the implications of timing errors on GPS accuracy.
Participants are actively engaging with the material, clarifying definitions and correcting misunderstandings. Some have offered insights into the relationship between the calculated and actual distances, while others are seeking further clarification on how corrections are applied. There is a recognition of the complexity involved in the mathematical aspects of GPS navigation.
There is an acknowledgment of the challenges posed by the mathematical concepts involved, particularly for participants at different educational levels. The original poster mentions being in year 12 and grappling with the material, indicating a potential gap in foundational knowledge.
denni0302
Hey all,
im doing a individual info search on GPS. i can understand everything (well its just a basic overview of GPS) but the one thing i can't get my head around is why the need for a fourth satellite? i know it corrects the timing as the receiver does not have an atomic clock. I've read 4 or 5 different explanations about it but i just don't get it..
here is an excerpt from wikipedia (i know its unreliable..), if someone can, can you elaborate on it and how they derive the equation? i can tell its REALLY simple, but its just not going through to me.
"It is likely that the surfaces of the three spheres intersect, since the circle of intersection of the first two spheres is normally quite large, and thus the third sphere surface is likely to intersect this large circle. It is very unlikely that the surface of the sphere corresponding to the fourth satellite will intersect either of the two points of intersection of the first three, since any clock error could cause it to miss intersecting a point. However, the distance from the valid estimate of GPS receiver position to the surface of the sphere corresponding to the fourth satellite can be used to compute a clock correction. Let denote the distance from the valid estimate of GPS receiver position to the fourth satellite and let denote the pseudorange of the fourth satellite. Let . is the distance from the computed GPS receiver position to the surface of the sphere corresponding to the fourth satellite. Thus the quotient, , provides an estimate of
(correct time) − (time indicated by the receiver's on-board clock),
and the GPS receiver clock can be advanced if is positive or delayed if is negative. However, it should be kept in mind that a less simple function of may be needed to estimate the time error in an iterative algorithm as discussed in the Navigation section."
http://en.wikipedia.org/wiki/Global_Positioning_System#Correcting_a_GPS_receiver.27s_clock
edit: also there's an image on wiki that is explaining it. hope it helps you help me with it :)
As the wikipedia says, if the receiver's GPS clock was perfect, the four sphere's would intersect in one point. However, because it isn't, they don't. Think about how precise the clock would have to be to have all those giant sphere's intersect in one really small dot...
But the GPS knows that they should be intersecting at on point, which means p4 should be equal to r4 (but it isn't due to the time problem). What that formula does is calculates how much time the GPS receiver is off by, so that p4 would in fact be equal to r4. See in the sample provided, p4 is less than r4, the real distance from the Satellite 4, which means that the GPS thinks the signal took less time to arrive that it actually did. This would mean that the GPS's clock is slow; and if you advance it by that amount provided, it'll be good again.
I hope this was clear, but if it isn't, ask again:)
-Tusike
thanks heaps Tusike!
it is pretty clear, thanks for referrin to that image.
im still a little baffled..
so the circle around fourth satellite(with r = p4) is the distance the reciever thinks it is from the satellite, but the real distance is r4? i understand now the correct time - receivers estimated time = margin of error thing. i don't know how that slipped past me lol.
ie. p4 = right
r4= wrong
and p4 - r4 = error
i hope that's right, because it sounds simple now :D
another question which is relataively easy lol (this stuff baffles me for some odd reason):
how do the receivers get corrected? does it correct itself after the 4th satellite 'tells' it how much its off by?
I think it's exactly the opposite way:)
r4 = right
p4 = wrong
r4-p4=error
I myself had to think about which was is right or wrong, but r4 is the actual distance, no matter what; and p4 is the distance calculated by the GPS using the formula p4=c*(time the gps think passed between the sending and the receiving of the signal).
As for your other question, I thought about it too, since if the 4th satellite's timing was off by a bit, the other three's were as well. I think what the Wiki says, "it should be kept in mind that a less simple function of da may be needed to estimate the time error in an iterative algorithm" is exactly what you need. If you scroll down to the Navigation section, you will find a bunch of formulas and all that tell you how the correction is done.
If I had more time, I'd look into those formula's, but I doubt they can be explained really simply because of the fact that they're not... Even I may not understand them. I love physics and everything, the only thing that really bothers me is that I just don't understand the math for those more advanced things, being only in 11th grade and not following any special math courses... So, for the correction, see those formulas, and good luck:)
ahh great haha.
i google defined pseudorange (the term used in wiki article) and states;
"A distance measurement based on the correlation of a satellite transmitted code and the local receiver's reference code, that has not been corrected for errors in synchronization between the transmitter's clock and the receiver's clock."
so to me it seems as though that is the incorrect one. which is exactly what you said. i think i was supposed to say p4 was wrong in the first place tbh but i got it mixed up LOL.
ill have a squizz at the formulas is navigation when its not 12:10am lol
PS: I am in year 12..but by the sounds of it youve been doing physics since year 9-10? my physics coruse started yr 11 (and physics teacher was horrible lol). this year I am pretty much learning what i was emant to learn last year and the new stuff O.o
thanks again tusike
  • · Replies 31 ·
9K
  • · Replies 22 ·
