What is the rate at which water flows out the tank in m^3/s?
  • Thread starter Thread starter lovelylm1980
    Rate Tank Water
The discussion focuses on calculating the water flow rate from a tank with a 0.6m depth and a 6m² hole at the bottom. The initial approach suggests using the formula Q= pi*r^4(p1-p2)/8L*viscosity, but viscosity is deemed unnecessary for this scenario. Instead, applying Bernoulli's principle is recommended, simplifying the calculation by ignoring the velocity term at the water surface due to the tank's large area. The key takeaway is to focus on the hydrostatic pressure to determine the flow rate without complicating factors like viscosity. The conversation emphasizes the importance of using appropriate fluid dynamics principles for accurate calculations.
lovelylm1980
A tank of large area is filled with water to a depth of 0.6m. A hole of 6m^2 cross section in the bottom allows water to drain out in a continuous stream. What is the rate at which water flows out the tank in m^3/s?
This is how I figure the problem should be solved:
Area= 6e-4m^2
h= 0.6m
P= rho*g*h= 1.00e3kg/m^3*9.8m/s^2*0.6m= 5880N/m^2
what I can't figure out is how do I get viscosity from the area
This kind of question probably belongs in the Homework Help section. Anyways...
Forget viscosity. (Unless they want you to include it; in which case: Lot's of luck!) Assume laminar flow. Apply Bernoulli's principle. Hint: Since the tank has a "large area", ignore the 1/2ρV2 term at the surface.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Let there be a person in a not yet optimally designed sled at h meters in height. Let this sled free fall but user can steer by tilting their body weight in the sled or by optimal sled shape design point it in some horizontal direction where it is wanted to go - in any horizontal direction but once picked fixed. How to calculate horizontal distance d achievable as function of height h. Thus what is f(h) = d. Put another way, imagine a helicopter rises to a height h, but then shuts off all...
