What is the relationship between stopping potential and the intensity of light?
Higher light intensity can lead to a higher stopping potential, but this relationship is complex and not straightforward due to the principles of the photoelectric effect. The intensity of light is related to the number of photons, while the stopping potential is influenced by the energy of individual photons, which is determined by their wavelength. Some experiments suggest that a reduction in light intensity can slightly decrease the stopping potential, indicating a nuanced interaction. The stopping potential is defined by the equation eVo = KEmax = hf - Wo, where Wo is dependent on the intensity. Overall, the relationship between stopping potential and light intensity requires careful consideration of both photon energy and the number of photons involved.
tnecniv
The higher the intensity of the light we will get a higher stopping potential.
Why is that so? is there any theory and formula to justifiy this behavior?
How is wavelength affecting the intensity of light?
Please advise.
Thank You
Science news on Phys.org
Are you sure a higher intensity of light leads to a higher stopping potential? That is contrary to the photoelectric effect!
The wavelength and intensity of light are independent properties.
Well, theoretically it doesn't. I just did and experiment on this my result shows that when the intensity of light reduces, the stopping potential, albeilt slightly, reduces as well. Possibly because
stopping potential, eVo = KEmax = hf - Wo
and since Wo is dependant on the intensity of light, this will in turn affect our stopping potential. I might be wrong so...yeah..
Likes ThelloW
Sorry to wake up the dead.
Stumbled upon this and it looked interesting.
When an electron is hit by a photon which has an energy below the work function, the electron is excited for a short period of time before returning to the initial state. So if the intensity of light is high it is possible for 2 or more photons to hit the same electron (albeit under very low probability) within this very short period of time, thus causing it to detach.
I think this may be a possible explanation.
*edit* Just to clarify, intensity of light is the amount of photons.
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
After my surgery this year, gas remained in my eye for a while. The light air bubbles appeared to sink to the bottom, and I realized that the brain was processing the information to invert the up/down/left/right image transferred to the retina. I have a question about optics and ophthalmology. Does the inversion of the image transferred to the retina depend on the position of the intraocular focal point of the lens of the eye? For example, in people with farsightedness, the focal point is...
