What is the speed of electric current?
  • Thread starter Thread starter mbsid786
    Current Speed
Electric current is primarily characterized by the drift velocity of electrons within a conductor, which is typically only a few centimeters per second. While electric fields propagate at nearly the speed of light, the actual flow of electrons is much slower. High current densities or specialized conductors could theoretically increase drift speeds to relativistic levels, but this would require extreme conditions. Such advancements might also lead to the emission of high-energy radiation and potential applications in space propulsion. Understanding these concepts is crucial for grasping the complexities of electric current in physics.
mbsid786
My teacher taught me electrons(current) inside conductor don't flow apace but they drift inside it. This drift in one direction due to electric field is called drift velocity. But now I m reading
"Electric current flows very fast through any conductor, resistor, or semiconductor.
In fact, for most practical purposes you can consider the speed of current to be the
same as the speed of light: 186,000 miles per second. Actually, it is a little less."
Oh man ! physics sucks me :D
Electric fields travel very fast but the electrons making up the current generally drift at very slow speeds.
You can calculate it, I just forgot how!
If memory serves me right, it's usually few centimeters per second for normal current densities.
It will take an incredibly high amount of current and/or very fine strand of conductor to take the drift up to relativistic speeds - if only there's such superconductor that can handle such extreme current density. But if it was possible, it might emit high energy radiation as well as appreciable amount of thrust (that could you could utilize for space propulsion)
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
