What is the Standard for Valve Pressure Ratings?
  • Thread starter Thread starter onestep
    Standard Valve
The discussion revolves around the standards for valve pressure ratings, specifically comparing PN16, JIS10k, and ANSI 150# ratings in the context of steam pressure applications. Participants explore the implications of these ratings for valve selection in boiler operations, considering temperature and pressure conditions.
  • One participant questions whether PN16, JIS10k, and ANSI 150# are equivalent in withstanding steam pressure, expressing confusion about the ratings.
  • Another participant clarifies that PN16 is a lower rating than ANSI 150#, while JIS10k is roughly equivalent in pressure rating but differs in dimensional specifications.
  • A participant inquires about the suitability of a cast iron body globe valve rated PN16 for boiler operations at temperatures between 150-200 Celsius and pressures around 10 to 12 bar.
  • In response, another participant expresses caution regarding the maximum temperature rating of the valve being equal to the operating temperature, while also providing a rough calculation of the operating pressure relative to the valve's maximum rating.
Participants express differing views on the equivalence of valve ratings and the suitability of specific valves for given operating conditions. There is no consensus on the best practices for valve selection in this context.
Participants highlight the importance of considering both pressure and temperature ratings in valve selection, noting that the relationship between steam pressure and temperature is critical. There are unresolved assumptions regarding the safety margins in boiler engineering.
Individuals involved in engineering, particularly those working with boiler systems, valve selection, and pressure ratings in steam applications may find this discussion relevant.
onestep
Hi,
I have a question.
Glove Valve
PN16, JIS10k , ANSI 150#, AMSE, all they equal same, in withstand the steam pressure?
I heard RN16 stand for 16bar pressure, but it's for steam too?
I'm confuse..
million thanks if anyone would teach me please.
PN16 is a lower rating than ANSI 150#. JIS10k is basically equivalent as far as pressure rating goes, but there are many differences in the valve/flange dimensional specs. ASME (Specifically ASME B16.5) is the pressure rating specification.
Steam pressure dictates steam temperature. Valves must be rated to the steam pressure that will be in the system.
thanks for the answers.. :D
1 more question,
lets say,
The boiler operation temperature are between 150~200 Celsius , and the operation pressure are between around 10 to 12 bar.
With attach a cast iron body globe valve, with PN16, Max temperature 200Celsius. It's suitable?
Thank you.
I suppose. I'd be a little suspicious of a valve with a maximum temperature of 200C if your standard operating temp is ~200C, but you'd probably be ok. Boiler engineering isn't something to guess at though, they store a great deal of energy and you don't want to under engineer them.
PN16 is rated to 16 bar, or ~230psi. At your 200C you'll be seeing a max operating pressure of ~175psi which is about 3/4 max rating. That should be ok.
ok, got it. Million thanks Travis King. :)
  • · Replies 18 ·
13K
27K
  • · Replies 39 ·
17K
