What is the suitable motor can be used ?
  • Thread starter Thread starter manal950
    Motor
For a simple car designed to carry five people, a golf cart motor, typically around 1.5hp and 36 volts DC, is recommended due to its affordability. Users are encouraged to explore resources for purchasing and understanding these motors. A 12V car battery can be used, but alternative rechargeable batteries may also be considered for better performance. For speed control, a variable resistor can be utilized to adjust the motor's output proportionally to the accelerator's pressure. Overall, selecting the right motor involves assessing the vehicle's weight, terrain, and desired speed while balancing efficiency and cost.
manal950
Hi all
we have a simple car which carry around 5 person ..
for that car we want use battery or electricity connected to motor to drive the car
Can please tell me which motor I can use here that able to move 5 person and It should cheap
because I don't have money hhhhh ? ...
can please give me picture for a golf cart motor
and how much will be ?
and now problem to use electricity form the battery of car witch is 12 V ?
or if there any battery can used and able to recharge
and my last questions
for
which device I can use for increasing the speed and slow down
I mean I want device that when I push it the speed increase and when increase more the pushing the speed is also increase and when I remove me foot the car will slow down
so I want device which make the speed proportional to the pushing
which is connected to the motor
here's a link with "how to" for electric vehicles.
http://ddmotorsystems.com/ElectricVehicles.php
if that doesn't go try this one
http://www.ddmotorsystems.com/ElectricVehicles.shtml
here's a 1914 electric car, which proves you don't need complex electronics
http://www.union.edu/N/DS/s.php?s=7260
http://news.cnet.com/2300-13833_3-6247323-10.html
and a short intro to a real pioneer of EE
http://edisontechcenter.org/CharlesProteusSteinmetz.html
old jim
A variable resistor in the field wire will control a DC motor.
There are many different types of motors that can be used for a car, each with their own advantages and disadvantages. Some common options include DC motors, AC motors, and brushless motors. The suitable motor for your car will depend on various factors such as the weight of the car, the terrain it will be driven on, and the desired speed and power. It is also important to consider the efficiency and cost of the motor. I would recommend researching different motor options and consulting with a professional to determine the best choice for your specific needs and budget.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
