What is the tangential acceleration of a flywheel particle during deceleration?
  • Thread starter Thread starter RaoulDuke
    Flywheel Torque
The discussion focuses on calculating the tangential acceleration of a flywheel particle during deceleration. The flywheel operates at a constant angular speed of 375 revolutions per minute (rev/min) and experiences an angular acceleration of -3.47 rev/min². At the moment the flywheel is at 75 rev/min, the tangential component of linear acceleration for a particle located 50 cm from the axis of rotation is derived using the formula: tangential acceleration = (angular acceleration) × (radius). The correct conversion of units from rev/min² to rad/s² is essential for accurate calculations.
  • Understanding of angular motion and angular acceleration
  • Familiarity with unit conversion between revolutions and radians
  • Knowledge of linear acceleration concepts
  • Basic proficiency in physics equations related to rotational dynamics
  • Learn about angular acceleration and its impact on rotational motion
  • Study unit conversion techniques for angular measurements
  • Explore the relationship between linear and angular acceleration
  • Investigate practical applications of flywheel dynamics in engineering
Students studying physics, particularly those focusing on rotational dynamics, as well as engineers and professionals working with mechanical systems involving flywheels.
RaoulDuke
The flywheel of a steam engine runs with a constant angular speed of 375 rev/min. When steam is shut off, the friction of the bearings stops the wheel in 1.8 h.
At the instant the flywheel is turning at 75 rev/min, what is the tangential component of the linear acceleration of a flywheel particle that is 50 cm from the axis of rotation?
Angular Acceleration: -3.47 rev/(min^2)
Tangential component of the linear acceleration = (angular acceleration)(radius to object)
I tried dividing the angular acceleration figure by 60 to make it in rev/(sec^2), then multiplied by r (.5 m), and ended up with the wrong answer. I tried multiplying that angular acceleration figure by 2pi to convert it to radians then multiplied it out, but still no dice. I have one attempt left. Do I need to clarify anything?
The units are rev/min2. 1 revolution is 2π rad and 1min2 is 3600s2, so you need to multiply rev/min2 by 2π/3600 to get it into rad/s2
ah, so I was close. thanks.
12K
