What is the total magnetic flux through the plastic of the soda bottle?
The total magnetic flux through the plastic of a soda bottle is calculated using the equation flux = B * A * cos(θ). In this scenario, the magnetic field is 1.95 T at an angle of 21° from vertical. The negative sign in the flux calculation arises because the problem requires the flux through the plastic, not the opening, leading to the rearrangement of terms from Gauss' law for magnetism. The flux through the plastic is derived as the negative of the flux through the opening, which simplifies the calculation. Understanding this relationship clarifies why the angle is subtracted from 180° instead of directly using 21° in the cosine function.
mnafetsc
An open plastic soda bottle with an opening diameter of 2.7 cm is placed on a table. A uniform 1.95-{\rm T} magnetic field directed upward and oriented 21^\circ from vertical encompasses the bottle.
flux=B*A*cos\theta
I have the correct answer, but I don't understand why it is negative instead of positive, or in other words why to i subtract 21 from 180, instead of just plugging in 21 into cosine.
It's negative because the problem statement wants you to find the total magnetic flux through the plastic, not the opening.
Sure, you could mathematically model the intricate, detailed shape of the plastic bottle, and then tediously calculate \int B \cdot dA of the plastic. But unless you have a computer with some expensive modeling software, this approach will take awhile. Fortunately there is an easier way.
Guass' law for magnetism states
\oint _S \vec B \cdot d \vec A = 0
Given what we know of the bottle (the plastic part and the opening part together form a closed surface), this can be written as
\int _{plastic} \vec B \cdot d \vec A + \int _{opening} \vec B \cdot d \vec A = 0
But we're only interested in the plastic part. But the opening part is the part that's easy to calculate. Fortunately, by rearanging the above terms, we can calculate the plastic part in terms of opening part.
\int _{plastic} \vec B \cdot d \vec A = -\int _{opening} \vec B \cdot d \vec A
And since you know
\int _{opening} \vec B \cdot d \vec A = A_oB \cos \theta
you can find the flux through the plastic part,
\int _{plastic} \vec B \cdot d \vec A = -A_oB \cos \theta
(Where Ao in the right side of the above two equations is the area of the opening -- not the area of the plastic)
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
