What is the voltage range of a Li-NMC battery?
Li-NMC batteries have a nominal voltage of 3.6V and are charged at 4.2V, with 4.0V suggested as a safe cutoff to maximize cycle life. Charging beyond 4.2V risks damage and potential hazards, while discharging below 3.0V can lead to battery failure. The optimal voltage range for performance and longevity is debated, with 4.0V being a common recommendation for extended cycles. Concerns about motor overheating due to voltage drops during discharge highlight the importance of maintaining a stable voltage to prevent excessive current draw. Ultimately, careful management of charging and discharging voltages is crucial for battery and motor longevity.
stargazer193857
They have a nominal voltage of 3.7V or 3.6V. They are charged at 4.2V, and disconnected when the charger says 4.0V. Does that mean they are 3.6V when they are empty, or are they overchaged when they are 4.0V? How low in voltage can they go and still have plenty of current? Thanks.
I'm designing a 36V lithium ion battery made from commercial 3.6V cells, since commercial 36V batteries are so expensive.
Maybe someone in the electrical engineering forum knows the answer.
I just know the voltage can be raised higher but it damages a lithium ion battery.
I looked at some charging/discharging curves. It is difficult to know what is optimal. Looks like they agree that charging at 4.2 volts is best, and certainly don't want to go above that. Some types charge lower than that. As for what voltage the battery should have when removed, that is up in the air. The lithium ion batteries can hold more charge than rated, and perform better with the higher charge. But if you go too high, they can catch on fire. Even if they don't, they can be more dangerous if over used once charged that high. However, at higher voltage, they put out higher voltage and have a much longer range. This comes at the price of shorter number of cycles. 4.0 volts seems to be a suggested cut off charging voltage. And the
Here is my particular battery:
http://img.weiku.com/waterpicture/2...y_separator_membrane_634579634333098075_1.jpg
Looks like when a nominal voltage of 3.6V is stated, that means that is close to dead, and is probably how it is shipped. If charged to 4.2 volts, its remaining amps are almost over at 3.7volts. If charged to 4.0 volts, its remaining amps are gone near 3.3 volts. Charging to 4.0 volts is suggested for max cycles.
So this raises a new issue: motor life.
Motors die when they overheat. If the voltage given to them drops, they output the same power by drawing more current, and overheat. If I'm riding an electric bike and asking for a constant 250W, I could damage the motor with the changing voltage of batteries. For this reason, corded motors probably last longer.
Now my question is, what beginning and ending voltages should I shoot for, and how much should I stay below the 250W motor rating to extend the motor life? Or does it already include a safety margin for this?
A "fully charged" NMC battery has to have 4.2 volts applied to it, but should deliver a "nominal voltage" of 3.6 plus or minus 0.5 volts. That just means that over the discharge cycle the voltage should be about 3.6 volts on average, but in reality it will usually be more or less depending on where in the discharge cycle the battery is at. If you only charged the battery using 3.6 volts the battery would have less capacity and output at a lower average voltage during the discharge cycle. If we think of 4.0 volts as being "fully charged" then the battery should behave approximately like the graph below (solid line).
That's right. As the charging voltage increases it stresses the battery and lowers the lifetime. The higher the voltage the more damage. For very long life you could charge the battery to less than full, but would obviously have to suffer from reduced battery capacity.
Yep. You have to decide on where you want the trade-off at. I don't see any real reason to charge to anything higher than about 4.0 volts.
I'm not sure how you're getting your numbers. It appears, at least to me, that at 3.6 volts your graph shows that you have approximately half of the battery capacity left if you're discharging it at 3c. If you're discharging it at 0.2c, then you'd have less than 10% capacity left. This means that discharging at a slow rate allows you to maintain a higher output voltage compared to discharging at a faster rate. See here for an explanation of c rates: http://batteryuniversity.com/learn/article/what_is_the_c_rate
Note that the discharge voltage itself varies with the current. A higher current decreases the output voltage because the batteries internal resistance has more of an effect when the resistance of the circuit is lower (hence why the current through it is higher).
I'm no expert on electric motors, but I wouldn't expect a drop of 0.5 volts to affect a motor that much. However I suppose you could use some sort of voltage regulator if you're that worried. (Someone more experience with this subject may want to step in)
Thank you, Drakkith, for yet another good explanation. So I will spend a little extra on ten amp hours instead of 7.5, to reduce my C number during charging and discharge and stay well above empty. I'm looking at 0.75C now instead of 1C, unless that is not enough to make a difference. I definitely want to stay far away from 3 volts since I don't have a smart charger, unless I build mine with a switch for multiple charging vultages. Either way, the motor won't like the lower voltage.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
