What is the volume of water in a cylindrical cumulus cloud of given dimensions?
  • Thread starter Thread starter scmejla
The discussion revolves around calculating the volume of water in a cylindrical cumulus cloud with a height of 3.6 km and a radius of 1.1 km. The calculations indicate that the lower and higher estimates of water volume are approximately 0.286614 m³ and 2.86614 m³, respectively. Participants express skepticism about these values, suggesting they seem too low for such a large cloud, which would typically contain much more water. The volume of water in a single drop is calculated to be 4.18879 x 10^-15 m³, leading to further questioning of the initial calculations. Overall, the consensus is that the estimated water volume appears insufficient for the size of the cloud.
scmejla
Does the solution to this problem look right?
A cubic centimeter in a typical cumulus cloud contains 50 to 500 water drops, which have a typical radius of 10 µm. For that range, give the lower value and the higher value, respectively, for the following.
(a) How many cubic meters of water are in a cylindrical cumulus cloud of height 3.6 km and radius 1.1 km?
Vdrop = 4/3 * pi * (10^-6 m)^3 = 4.18879(10^-15) m^3
Vdrop*50 = 2.0944(10^-13) m^3/(10^-2) m^3 = 2.0944(10^-11)
Vdrop*500 = 2.0944(10^-12) m^3/(10^-2) m^3 = 2.0944(10^-10)
Vcloud = pi * 3.6(10^3) m * (1.1(10^3) m)^2 = 1.36848(10^10) m^3
Lower value = 2.0944(10^-11) * 1.36848(10^10) m^3 = 0.286614 m^3
Higher value = 2.0944(10^-10) * 1.36848(10^10) m^3 = 2.86614 m^3
Hello Scmejla. Interesting problem. You know that's a big cloud but you're saying it has only .2 m^3 of water. That's only a few buckets full. Surely it has more than that, few truckloads at least. I checked your work. You calculated volume of water in a drop (in cubic meters). That's 4.18*10^-15. For the lower limit, there are 50 of those drops in every centimeter and 1 million cubic centimeters in a cubic meter. Thus, the low limit of the amount of water in 1 cubic meter is how much?
Edit: Alright, maybe 10 or 12 you know what I mean. So how many bucket-fulls of water are in .28 m^3? You know, without calculating it, I'd guess now around 15. I say we figure how many bucket-fulls of water are in that cloud anyway. :smile:
Thanx for setting me straight, I should have realized that was an awful small amount for such a big cloud.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
