What is the width of a spectral line?
  • Thread starter Thread starter Pushoam
    Line Width
Pushoam
The answer is no as it is not dimensionally correct.
Right?
No. You cannot make that argument since you are told explicitly what the units involved are (essentially telling you that the constant in front has units sqrt(K/u)).
