What is the Y-component of T1 and T2?
  • Thread starter Thread starter rickstarr93
    Mass Speaker
The discussion revolves around calculating the y-components of tension in a problem involving a speaker hanging from wires. The tension in wire 1 is given as 35N, and the user attempts to find the mass of the speaker using the equation m = (T1y + T2y) / g. However, confusion arises regarding the need for both x and y components of the tensions, as the user initially only considered the y-component. Participants emphasize the importance of drawing a free body diagram and correctly applying trigonometric functions to resolve the tensions into their components. Ultimately, the user is advised to clarify their understanding of vector components to accurately solve the problem.
rickstarr93
A speakerh angs from the ceiling by a pair of wires, as showin the diagram below. the tension in wire 1 is 35N. What is the mass of the speaker?
Given from the problem and picture.
Wire1=25 degrees
Wire2=55 degrees
Tension in wire1= 35N
Tension in wire2=18.02N
F=ma
x=T1sin(x)-T2sin(x)
This is what I got but didn't get full points becasue I am missing the Y component?
x=35sin(25)-T2sin(55)
T2=35sin(25)/sin55
T2=18.05
Then we used this equation
T1y+T2y-mg
0=T1y+t2y-m(9.8)
Rearange and plug in numbers:
35+18.05/9.8
m=5.41kg
She told me I am right all the way up to the last part (35+18.05/9.8) and was told I'm need the y-components..but I solved for it?
Thank you!
You didn't use the y components.
You have m= (T1y+T2y)/g = (35+18.05)/9.8
i.e. T1y=35N
but are you not told that T1=35N ?
if T1y=35N as well then T1x=0N - does that make sense?
So i need to find my x-components of T2x and then have both sides equal to each other?
But if T1x=0n then that is not relative to the equation?
Sorry for the questions, I"m still a bit confused.
You need both x and y components.
Draw a free body diagram for the speaker.
Divide the forces (tensions) into components parallel and perpendicular to gravity (easiest approach).
The horizontal forces sum to zero.
The vertical forces sum to zero.
You should end up with two equations and two unknowns.
Note:
if T1x=0 then there is no x component: what direction must T1 be acting in?
Does that fit the description?
so I would have to do instead of sin, I have to use cos?
35cos(25)/cos(55)= 55.30
You should use your understanding of trigonometry and vectors to solve the problem.
In long answers, you should show your understanding by what you write.
What you wrote in post #5 reads like you have just randomly guessed that you need to change all the sines to cosines as if you have not understood anything that has been suggested before.
If you won't take suggestions, I cannot help you.
If you don't answer questions, I cannot help you.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
