What limits the heating capabilities of a room?
  • Context: High School
  • Thread starter Thread starter Barchie
    Heat Limit
The discussion revolves around the limits of heating capabilities in a room, specifically examining how a heat source, such as a candle or electric filament, affects the temperature of the air within the space. Participants explore theoretical scenarios, assumptions about heat loss, and the implications of different heating methods.
  • Some participants question whether a candle can continuously raise the temperature of a room, considering factors like the temperature of the flame, the size of the flame, and the size of the room.
  • One participant suggests that the amount of oxygen in the room would limit the heating capability, especially if ventilation is introduced.
  • Another participant proposes that if ventilation is managed such that heat loss does not exceed heat input, the room could eventually reach the temperature of the flame.
  • There is a suggestion that using an electric filament as a heat source eliminates the oxygen limitation and allows for a more consistent heating process.
  • Concerns are raised about the heat radiation from the room as it warms, indicating that the room will radiate heat more as its temperature increases, which could limit the maximum achievable temperature.
  • It is noted that even with perfect insulation, the room's temperature cannot exceed that of the heating unit, establishing a theoretical maximum temperature based on the heat source.
Participants express multiple competing views regarding the effectiveness of different heating sources and the factors that limit heating capabilities. The discussion remains unresolved, with no consensus on the best approach or the definitive limits of heating a room.
Assumptions about heat loss, ventilation, and the nature of the heat source (candle vs. electric) are central to the discussion, and the implications of these assumptions are not fully resolved.
Barchie
Hey All,
Maybe a silly question, but... Is there a limit to how much a certain element can heat a body of air, say a room or an oven?
Maybe more clear with an example.
If i had a candle lit in the corner of my room for ever, would the temperature of the room continuously rise (slowly) until it reached the temperature of the flame?
What would the limiting factor be? The temperature of the flame? The size of the flame? The size of the room?
(Assuming there was not heat loss from the room...)
Science news on Phys.org
Amount of oxygen contained in the room. If you want to ventilate it - you must revise no-loss assumption.
No-loss assumption is several orders of magnitude non-realistic if you think about candles and rooms.
Fine so if the losses from ventilation never outweighed the heat being provided by the candle would the room eventually one day reach the temperature of the flame? (if the candle burned forever)
If you ventillate such that you just remove some of the hot air (full of CO2) and provide fresh air at room temp and more candles, you have a stationary process: cool_candle+cool_air=>hot_hot_air_at_the_flame_temp, which hot air will finally fill the whole room.
this candle thing opened the door for too many arguments...let's just use an electric filament! No need for oxigen. :biggrin:
and yes, the gas/air in the room will eventually get as hot as the heat source but it will approach it in an exponential manner since the hotter the gas the less heat it absorbs from the heat source. In other words, the heat transferred from the heat source to the gas is proportional to the temperature difference.
Yes, candle won't work as there are confounding elements. Not just oxygen but also limited fuel (it's only a candle, it'll burn down). To eliminate these problems without totally going to an electric element, you'd need to supply oxygen and some flammable gas. Now you've got an unending heat source!
Of course, you've still got to vents the byproducts somehow, or your room will eventually burst from pressure...
Hm. So an electric element is a mroe expedient heater...
As gsal points out, the next problem is that your room will start to radiate heat. The hotter it gets, the more it will radiate. This is the limiting factor. You can insulate all you want, but there is no such thing as a perfect insulator.
But if you managed to maximize insulation, then eventually the temperature in the room will reach the temperature of your heater. It will not go higher than that.
So the maximum temp of the room is limited by the maximum temp of your heating unit.
  • · Replies 33 ·
  • · Replies 17 ·
  • · Replies 66 ·
