B What parameters of physics are most important to the existence of life?
The discussion centers on identifying the key physical parameters necessary for the existence of life, emphasizing that life emerged under specific conditions shaped by fundamental physics. Participants debate the significance of various constants, such as the speed of light and the fine-structure constant, and their roles in enabling life. There is a consensus that no single parameter can be isolated, as life results from a complex interplay of multiple factors, including chemistry, heat, and pressure. The conversation also touches on the anthropic principle and its implications for understanding life’s emergence in the universe. Ultimately, the thread highlights the complexity of the question and the interrelatedness of physical laws that contribute to the conditions necessary for life.
Suppaman
TL;DR Summary
There are laws or parameters of physics, I am told, that allow the sun to work as it does to provide us with light and heat. What attribute of physics are most important to "life" being able to exist.
The universe after the big event was a lot of lifeless stuff. However, as things settled down the rules behind the curtain were such that life was allowed to develop, they may have even been such that they encouraged the things to happen that were conducive to the process that has resulted in life. Some rule, some physics value that if it was somewhat different it is considered unlikely that life would have been likely. I am not asking what a parameter is what it is or how that parameter was established, I am interested in which parameters are most important to "life" existing. This also assumes that in a universe that is consistent from place to place that life is also likely from place to place.
The answer to this question is more a matter of taste and opinion than a matter of fact. Life as we know it depends on so many specific circumstances, that you can run through entire quantum mechanics and astronomy and point to any single parameter. My opinion is
\hbar
since without the uncertainty principle physics would be completely different and nothing in our world would ever have happened: from stars and galaxies, to molecular chemistry for life.
Likes anorlunda
I will agree, probably because it is logical. However it is not a parameter, it just is. My question was about a value that was most important.
The atomic number of carbon?
I think that is not a changeable parameter, is it?
This is quickly going down the path of "what am I guessing?"
You need to tell us the rules first. Not just say "No, that's not it" to the responses.
As an example of a rule, parameter. The speed of light is a parameter and the rule is that you can not exceed that parameter. I have no idea if that parameter was +/- 10 percent it would affect the potential for life. Now, I am sure there are more knowledgeable people who know of the other parameters and or rules. Does this help?
So c is a parameter and h is not? This seems very arbitrary to me.
Sorry, I missed h, I was just looking at the text. "without the uncertainty principle physics would be completely " is more than a change in value for h. Was the answer implying that the value of h is critical for live existence?
Yes, it is.
But could we decide on a single parameter that is independent of the others?
I think the question in the OP is a bit too naive to warrant serious discussion - unless we are in the realms of a Sci Fi story scenario which could ignore the interrelatedness of the whole of Physics.
c is far more fundamental than just being a 'parameter'. Everything starts with c.
Suppaman said:
Summary: There are laws or parameters of physics, I am told, that allow the sun to work as it does to provide us with light and heat. What attribute of physics are most important to "life" being able to exist.
This is far too general.
I could say the electron's charge or mass as life is just a specific chemistry and chemistry is just electrons.
You can't have life without light heat therefore you need stars therefore gravity or a few nuclear parameters are key.
Too general
Yes, we need a place for life to emerge and we had that for a billion or more years before it did. It is at this point where life started that I am looking for the key physical laws or parameters that encouraged this to happen. I am not looking for an explanation of how life started, just what was necessary for it to happen. The values of these constants, the rules that are there, in the background that allow life to get a start. Which rules or parameters that if they were not what they are the Earth would just be a wet ball of rock with nothing happening.
It is best to choose a dimensionless constant, such as the so-called fine structure constant, when considering this issue. (Constants such as the speed of light ##c## or Planck's constant ##\hbar## are not dimensionless, so their values depend on conventions chosen by humans, for example, the length a meter.)
From the Wikipedia article on the fine structure constant ##\alpha##:
The anthropic principle is a controversial argument of why the fine-structure constant has the value it does: stable matter, and therefore life and intelligent beings, could not exist if its value were much different. For instance, were α to change by 4%, stellar fusion would not produce carbon, so that carbon-based life would be impossible. If α were greater than 0.1, stellar fusion would be impossible, and no place in the universe would be warm enough for life as we know it.
Likes jim mcnamara
I mentioned that part about how the sun is able to provide the energy we need in my original post. I am looking for things we had on the Earth when life began. There must have been some combination of things, things governed by the rules and parameters here one this wet ball of rock. If they had not been what they are, no life. What are these laws and parameters? It may be that a lot of these laws and parameters are dependent on some other law and parameter. That would probably help science figure things out. For my question, I would like to know what the current thinking is, what do we think are the key settings of the life generator?
For life, large systems of particles and molecules rather than anyone physical parameter have to be considered.
What's the most important parameter for baking a cake?
The exo planets that may be able to support life have to tick a few boxes, light / heat distance from its star, liquid water. Chemistry is the same all over the observable universe so all the building blocks for life are already there.
The Earth has a moon and a tilt which are important for tides seasons etc.
Life on Earth could not have got going during the bombardment period as the surface was too hot/ molten.
Water was thought to delivered via comets and asteroids.
How special is the Earth is a better question.
It may be a better question but it is not my question. My question is being asked at the point where the most important step to life happens "tomorrow", standing on this wet ball of rocks at year billion, what parameters are most important to ensuring life begins.
According to some research deep sea vents could be the key to go from a sterile rock to the first protocells.
So liquid water, alkaline pH, heat from Geological activity.
https://www.livescience.com/26173-hydrothermal-vent-life-origins.html
Likes PeroK
I am not asking here how life started, we all agree it did, I am asking what laws and or their parameters were most necessary to this being a successful event here on this wet ball of rocks?
Given that we are 20 messages into this thread and you are still telling people "that's not what I mean", isn't it time to consider if you have asked an unclear question?
Likes davenn, sophiecentaur and pinball1970
Perhaps. I believe one of the things the advisors here can do for a poster is to help them ask the best questions. Can you help me properly phrase my question? What is there about " What attributes of physics is most important to "life" being able to exist." that is not clear to those who are answering? Please advise.
The answer is there is no one parameter, life involves mass heat pressure chemistry. This involves ALL the parameters
I suggest on all your questions you give us a multiple choice.
  • Haha
Likes pinball1970
If we're not careful we will get into yet another Top Trumps game. Which is the most important aspect of a car? 0 to 60 time? mpg? how many seats? Perhaps the number of wheels (but one would do at a pinch - or even none for a hover car) The Universe is not a good subject for Top Trumps.
There can be no isolated factor that promoted the evolution of life. Possibly a more 'discussable' question might be "discuss how many different factors do you need to get 'right' if you want life forms to develop? But that's Biology and not Physics.
The fact is that we are here and we have evidence that there has been some form of life around for a few billion years.
One extra question could be to ask why things changed to cause the totally microbial life suddenly to produce the more complex Eukariotic life. Did conditions change to introduce another vital factor which changed the 'rules' which had kept microbes chugging along fine and allowed our simple multi-celled ancestors to get started? But that again is Biology - unless there was some Physics related parameter that changed. Personally I don't like the implications of the Anthropic Principle because it just looks to me like a substitute for religion. As far as I'm concerned:
We're here because we're here because we're here because we're here.
To the tune of Auld Lang Syne
(Liquid)Water is necessary. At least for our, carbon- based type of life. Is that what you are looking for?And, I believe, so is the fact that water expands when it freezes.
Indeed. Both. The dipole water is the most important fact to us. This tiny nondescript angle.
And the list is endless, including the existence of Jupiter, our Moon, down to HUP! There might be life in some form without Jupiter or Moon, but our universe wouldn't exist as is without HUP.
fresh_42 said:
Indeed. Both. And the list is endless, including the existence of Jupiter, our moon, down to HUP! There might be life in some form without Jupiter or moon, but our universe wouldn't exist as is without HUP.
HUP?
Heisenberg's Uncertainty Principle.
This is going off on an undesirable trek. I started with a thought, also mentioned by someone,
"The anthropic principle is a controversial argument of why the fine-structure constant has the value it does: stable matter, and therefore life and intelligent beings, could not exist if its value were much different. For instance, were α to change by 4%, stellar fusion would not produce carbon, so that carbon-based life would be impossible. If α were greater than 0.1, stellar fusion would be impossible, and no place in the universe would be warm enough for life as we know it. "
This vale allows the physical universe to have a proper environment for life. My original, what other parameters are also just as essential for life to get started. If it is determined that almost all the laws and parameters have to be what they are for life to exist, that would be disturbing for a lot of people. I was asking about the top one or two, not all of them.
This is an a posteriori argumentation. It is likewise "disturbing" to see the list of all "parameters" which must be given, in order that you <insert an event of your choice, e.g. have seen last year's super bowl>. In fact it might only have depended on whether you live in the US and are male or not. But if you list every single invention and discovery that is needed to have such an event at all, then it looks like a miracle. I doubt that most of us would call it such. You cannot conclude anything from such a list!
Your question as in the title cannot be seriously answered. And you even started a second thread on basically the same subject, which I suppose is also unanswerable. E.g. I could easily reduce "life" to the simple fact that a water molecule is a dipole! This isn't a miracle. It is quantum mechanics!
Thread closed.
Likes davenn and pinball1970
