What really makes the lamp comes on, tension, current or potency?
The discussion centers on the factors that make a lamp illuminate, specifically the roles of voltage, current, and power dissipation. It is clarified that a lamp designed for a specific voltage, such as 1V, will operate effectively at that voltage, dissipating 4W of power. If the voltage is lower than the specified amount, the lamp may not light up at all or will be dimmer, while exceeding the voltage can cause the filament to overheat and burn out. The conversation also touches on terminology differences, with participants using terms like "globe" and "light bulb" interchangeably. Understanding these electrical principles is crucial for proper lamp operation and longevity.
jaumzaum
Sorry for the stupid question, but what actually makes the lamp comes on, the tension applied to it, the eletric current that passes through it or the potency dissipated by it?
I think its the current but I'm not sure and I don't know why?
But if it were the current, what makes the lamp burn, and what makes it not comes on?
I mean , I know that if it were the current, a big current will make it burn, but how much? A lamp of 4W and 1V for example, has a current of 4/1 = 4A, so 4,00001 A would burn it?
And 3,999999 A would make it not comes on?
A lamp labelled "4W , 1V" is designed to be operated with a 1V potential difference applied to it, at which stage it will dissipate power at a rate of 4 Watts.
If you apply a slightly smaller Potential difference, it will dissipate slightly less that 4W - but it is not a proportional al arrangement [meaning 0.5 Volts does not automatically mean 2W]
If you apply slightly more than 1V, the lamp will try to dissipate slightly more that 4W.
Given "engineering design tolerances" for actual products in the real world, the lamp will "succeed" for a while as the voltage is increased. The lamp will be brighter than usual - the filament will be hotter than the designers planned. Increase the voltage gradually and eventually the filament will get too hot and melt - he lamp will burn out.
NOTE: not all that comfortable with your original terms Tension and potency.
What you called potency dissipated should have been power dissipated.
What you called Tension applied should have been Potential Difference applied - or at a pinch; Voltage applied.
Sorry, I am not too used with Amercian Physics notation (I'm brazilian by the way)
Thanks, for the answer
I still don't understand a thing:
If a little potential difference in applied to the lamp, in the example 0.15V, would it be less brighter th an usual or won't it light all?
Actually I'm Australian, but,
If you apply less than the specified/design voltage it will be less bright. The limit for most of the globes I have used is about half - so if it is a 1V globe, you need at least 0.5V to notice anything.
The way a globe works is, the higher the applied Voltage, the hotter the filament gets.
With a very small voltage it might be only a little warm, and you wouldn't notice anything.
Increase the voltage and the filament will get "red hot", and appear red.
Increase further and the filament gets white hot and starts to glow like a lamp is supposed to.
Increase far enough, and the filament will get so hot, it melts.
So 0.15 V and your globe would probably NOT light up at all.
The specifications on the globe tell you what voltage to apply to have it in a good operating state - glowing nice and bright but not melting..
Note: I reverted to the term globe: when our "lamps" burn out, we get a new globe. We use the term light globe: A lamp is the device that has the light globe in it, as in "a bedside lamp may have a 40W globe fitted".
Do you call it globe in Australia? I know it as light bulb.
ehild
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
