What the test question that just bugged the crap outta me
  • Thread starter Thread starter schattenjaeger
    Test
The discussion revolves around the differential equation y' = 2√y and the confusion regarding the uniqueness of solutions at the point (1,1). The user initially derived two solution curves, x^2 and (x-2)^2, but questioned the implications of finding two curves at the same point, suggesting a contradiction with the existence and uniqueness theorem. It was clarified that only one of the curves, x^2, satisfies the original differential equation at (1,1), while (x-2)^2 does not due to the introduction of an extraneous root when squaring. The key takeaway is that the presence of two curves does not imply both are valid solutions at that point. This highlights the importance of careful consideration when solving differential equations to avoid extraneous solutions.
schattenjaeger
we were given the DE y'=2sqrt(y) that was how it was given, I didn't take the square root myself and thus forget a +and-
so using a bernoulli equation I got (x+c)^2(I think, I'm doing this from memory)
then the next part asked to find two solution curves for the point (1,1), so x^2 and (x-2)^2, right?
THEN it asked for the solution guaranteed by the existence and uniqueness theorem at (1,1), but didn't I just find TWO solution curves for that same point, which means there ISN'T an unique solution? And to further confuzzle matters if I actually apply the theorem it seems like it SHOULD have an unique solution at (1,1)
Take a closer look at the solution y=(x-2)^2. It has a negative slope at x=1. If y'<0, then according to your DE 2\sqrt{y}<0, which is impossible.
aw hell, so when it asked me to sketch two solution curves THAT was the "trick" question?
or were they both solution curves but they passed through the point or something? We'll go over it on Monday but I hate waiting to know
They are not both solutions at x=1. y=(x-2)^2 simply does not satisfy the differential equation at x=1. What happened was that you introduced an extraneous root when you squared y^{1/2}.
