What time and at what distance do two objects meet?
  • Thread starter Thread starter Kuroida
    Time
Two objects, A and B, are moving with different speeds and acceleration, with A traveling at a constant speed of 10 m/s and B starting from rest with an acceleration of 1.2 m/s² after a 5-second delay. To determine when and where they meet, the equations of motion for both objects must be set equal, considering A's time is t+5 seconds. The quadratic formula is used to solve for the time variable, yielding a time of approximately 20.69 seconds for object A, which can be adjusted for object B's delay. The distance at which they meet can then be calculated using either object's motion equations, confirming the solution process.
Kuroida
I'm new at this :S
Question:
Objects A,B
A: speed = constant = 10m/s
B: starts 5.0 sec after A, starts from rest, acceleration = 1.2m/s squared
a) what time do the two objects meet? (relative to A)
b) at what distance do they meet (relative to A)
The 5 kinimatic equations.
Quadratic formula
(no clue how to type them in sorry) :(
Ok. I have NO clue how to start. :s
For a) you have to find delta t...right? o.0
So is it
V1=10
V2 = 10
a=0
t=?
Use 4th equation to find delta t...but that doesn't work because since a is 0 delta t gets crossed out ...o.0
What I did was for b):
a=1.2
t=5 sec
V1 = 0
d = ?
Use equation 1 (delta d = V1 x delta t +1/2a(delta t) squared)
Sub the numbers in: d= 0x5 + 1/2(1.2)(5) squared
Answer = 15m (?)
My teacher said you needed the quadradic formula though...and really I have no clue what I'm doing -_-
Equations of motion for objects:
(object a)Uniform motion: X=vt, (Object B)-Uniform Acceleration: X= 1/2at^2
Since object A start's 5 seconds before object B, object a's time should be t+5. Using this you should be able to set the two equations equal to one another using x, and then solve for t. Then you can take that time and substitute it into either equation to find the distance at which they meet.
thanks. I think I got it by now
Just another question.
When I use the quadratic formula to solve for t ...
My equation is -0.6t^2 -10t -50.
t= 20.69
Do I add 5 to this number to make up for the time?
Yes, but when you do part b, use 20.69 for t and use one of the equations you set equal to one another. you can use 25.69, but you would have to modify the equations to x=vt and x=1/2a(t-5)^2.
