What Type of Valve Should I Use to Control Water Flow in a Heating Process?
The discussion focuses on selecting an appropriate valve type for controlling water flow in a heating process. Participants explore the requirements for a valve that allows water to flow into a container under specific conditions while preventing backflow once the tank is full. The conversation also touches on potential modifications for a different container shape, specifically a long coil pipe.
  • One participant suggests a float valve that shuts off when the water level rises sufficiently to close it.
  • Another participant proposes a simple float type check valve, noting that it would work well if the head pressure is low and describes its mechanism involving a buoyant ball sealing against a tapered seat.
  • A later reply introduces a complication regarding the design, asking if the valve can be calibrated to introduce a delay in water flow when using a long coil pipe, while still allowing separation of streams inside the pipe.
Participants generally agree on the use of float valves or check valves for the initial design, but the later proposal regarding the coil pipe introduces uncertainty and requires further exploration, indicating that the discussion remains unresolved.
The discussion does not address specific limitations regarding the head pressure or the precise calibration methods for the valve in the context of the coil pipe scenario.
JJ21
Hi all,
Right, this may be a bit hard to explain but I'll do my best. Hopefully attached is a sketch of the situation. The water flows from the tank into the "rigid container" through valve (1). This tank is then heated until the water reaches boiling at which point the thermostatic valve opens draining the water.
The question is I'm looking for valve (1). It must let the water flow into the container when the container is empty or when the water has drained from the container (due to the hydrostatic pressure exerted on it by the reservoir placed higher than the container) but once the tank is full it must close and definitively separate the water in the tank to the water in the container being treated.
This may be a simple valve but I'm not really a connoisseur so I was wondering if anyone out there knew what type I'm looking for??
Thanks in advance
JJ21 said:
Hi all,
Thanks in advance
You need some type of float valve. One that shuts when the water level rises enough to close it.
CS
a simple float type check valve would work well as long as the head pressure was low.
It is basically a cage with a tapered seat at the top. The ball is boyant in water so as the container fills the ball seals in the seat.
You could add a calibrated spring under the ball to compensate for higher head pressures.
Brilliant, thanks for you help.
Just to maybe complicate this a little bit further, instead of a single cubic container it was a long coil pipe. Is there any way to calibrate the valve in order to let the water flow from the pipe through the outlet thermostatic valve while introducing a delay before the inlet water enters? Therefore separating the two streams while inside the pipe.
Thanks again
  • · Replies 16 ·
  • · Replies 34 ·
  • · Replies 31 ·
27K
