What Units Should Acceleration Be Measured In?
Acceleration can be measured in m/min², but it is not the standard unit, which is m/s². The x-axis in the discussed graph is in minutes, while the y-axis is in m/min, leading to potential confusion in unit consistency. Converting time from minutes to seconds before graphing is recommended for clarity and adherence to SI units. Ultimately, the key is to ensure that the units represent distance over time squared, regardless of the specific measurement used.
J_o_S
the x-axis is in minutes, the y-axis is in m/min.
I know that the acceleration = the slope.
should my final answer be in m/min^2 ?
or should acceleration always be in m/s^2 ?
or does it not matter? :confused:
thanks :smile:
There is nothing wrong with m/min^2 aside from it not being standard. Your best bet is just graphing it against seconds by converting your data from minutes to seconds BEFORE graphing.
yeah if I was taking down the data I would.
This is just a question on an assignment, where the graph is given.
Its an easy question, but after I did it the answer just doesn't look right to me, so I figured I'd ask.
acceleration has been in m/s^2 everytime I have come across it.
That is because meters and seconds are the SI units for time and distance. It is the international standard.
As whozum said, no problem at all. The important thing is that the units are distance over time squared. Remember that you can always convert between the standard m/s^2 and the non-standard m/min^2.
